Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 05-18-2006, 08:54 PM
terence123cars terence123cars is offline
'95 E150 351 Windsor Transmission Down Shifting
Hi Folks'
My daughter has a problem with her van. It downshifts on the straight an level. No load conditions and it occasionally shifts from overdrive (4th gear ratio) to 2nd, (engine roaring) when you lift your foot, it will shift back to 3rd and then 4th (overdrive) Otherwise transmission runs great. I'm thinking, only two things cause an upshift, Change in Manifold pressure or/and throttle position, plus of course the shift lever. I don't have a Haynes for this model, has anyone got any suggestions. By the way, the fluid looks great, nice and red and no burnt smell to it
Terry (Terence123Cars)
Old 07-06-2006, 09:01 AM
Re: '95 E150 351 Windsor Transmission Down Shifting
Originally Posted by terence123cars
Hi Folks'
I found the problem. It was the neutral switch. It is actually the Transmission shift selection sensor that is mounted under the driver's seat, under the van.
We changed it out and that was the problem. The tranny shifts perfectly now.
