AC/Heater Vent Problem
Hello everyone. I have a 99 gp gt with the digital dual climate control. Air will not blow out of the vents, hot or cold. All blower speeds are working correctly but the air will only come out of the defrost vents, changing the mode doesnt really do anything. I am wanting to fix this problem myself but I need an idea of where to start. Is it more likely that my problem is the control unit, some vent door thing, or somenting else? Any help would be greatly appriciated.
Thanks, |
Re: AC/Heater Vent Problem
Sounds like the accessory vacuum needed by the HVAC system is missing. Check the vacuum line that comes off the intake manifold that loops around by the battery and engine compartment fuse box and then feeds into the firewall to a distributor block by the blower motor assembly. From there it branches out to the various actuators which are vacuum and electrically controlled.
BTW - A lot of times when the battery is replaced the vacuum line coupler located by the battery/inner fender gets disconnected.
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 05-19-2006 at 01:23 AM. |
This has happened to me a few times and the problem was exactly what Bob describes. I reconnected the vacuum line and all's well.
Thats exactly what my problem was. The line was rubbed through where it went by the battery. Thanks for the help. I wish all fixes were this cheap.
I wonder if this could be causing the interesting "groinka, groinka" sound I can hear in the cabin sometimes. Especially since I'm not getting great airflow either.
Goethe once said, "A useless life is an early death." In Goethe's terms, many of us are already dead. -------------------------------------------------
For airflow problems check for any debris or obstruction in the intake cowling and blower motor area. If you have a cabin air filter installed it may be clogged and just needs cleaning or replacement.
Hi Guys,
Had a problem with my 89 GP not going to vent and checked out the vacuum line by the battery and found it was broken! lossened the brace, took out the washer res. and used rubber line to fix and whoala, problem solved. Just wanted to thank ya'll. This had been driving me nuts for a week now..... Mark 89 commuter GP 97 Crown Vic PI 90 F350 4x4 |
