Old 05-18-2006, 06:53 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
Question another strange occurance
very rarely this happens to my car. When I start the car, the engine races up real high and then slowly comes back down to normal. It usually only takes it about ten seconds to return to normal idle. If I put the car in gear while it's doing its high rev thing, the car lunges forward and usually dies. Because of this I usually just let it rev high for the few seconds, wait for it to calm down and return to normal. Does anyone have any idea what is wrong here? It only does this about once every two or three months. I am so confused on this one.
Old 05-19-2006, 08:04 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: another strange occurance
A racing idle that settles down is usually a bad or sticking IAC (Idle Air Control) motor. It's a small stepper motor that works similar to a choke on a carburetor, regulating the amt of air allowed into the engine at idle and part throttle.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-19-2006, 05:09 PM
gw84's Avatar
how much do they generally cost to replace?
Old 05-20-2006, 08:06 AM
richtazz's Avatar
The part is about $40, and it is ver easy to install. It is mounted to the throttle body with 2 screws. Make sure you clean out the passage it is in, so if there is carbon build-up, it doesn't make the new one stick.
Old 05-20-2006, 11:18 AM
gw84's Avatar
thanks, I'll look into that
