Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-18-2006, 06:01 PM
shearphysics shearphysics is offline
stupid question
does anyone know what the point of the vaccum line on the side of the valve cover going to the intake pipe is for,what it does,do u need it. im building a motor and if i dont need it im going to weld it closed. thanks it a 1g.
Old 05-18-2006, 06:11 PM
nova1313's Avatar
nova1313 nova1313 is offline
Re: stupid question
you mean where the PCV valve is? It's recommended you have it. It keeps pressure balanced in there. Without it pressure might build and you will probably blow gaskets. If it's what I think your talking about that is, I can recommend possibly putting an inline filter in though since oil does tend to travel through it sometimes.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 05-18-2006, 06:42 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: stupid question
No, I dont think he is talking about the PCV valve. The line your talking about isin't a vaccum line, its just a breather, but im not sure if you can close it up.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-18-2006, 07:21 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: stupid question
You are going to need it.
1991 GSX 2.3 Stroker
Old 05-18-2006, 08:07 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: stupid question
it is the PCV and it is not a good idea to plug it up or let it vent to the atmosphere.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 05-19-2006, 07:25 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: stupid question
It is NOT the PCV, he's talking about the breather like Silver said, and you can not close that off. The reason that you have that is so the pressure in the valve cover can escape via the breather into the intake (which is never good because sometimes oil finds its way through the line and it runs into your throttle body and it can run through the small holes in the bottom of the throttle body and clog the IAC motor). So what I would do is just put one of those small breather filters you can get from like Autozone and put that on it.
The PCV valve is on the back side of the valve cover and that takes pressure from the block and releases it into the valve cover so it can escape.
Old 05-19-2006, 08:48 PM
Re: stupid question
thanks for info
Old 05-19-2006, 08:54 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: stupid question
The more boost you run more likely the more oil to come out that hose. What alot of us do is make or by a oil catch can. Alot of people do not like the idea of that oil going into the turbo through the IC piping. What alot of poeple also do cheap is get a inline gas filter, a see through kind and just cut the hose and connect it They are like $3.20, thats what i was doing for the longest time.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 05-20-2006, 02:08 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: stupid question
Just want to clear a few things up.
The PCV valve is for Positive Crankcase Ventilation. When the intake manifold is under vacuum, it opens and a vacuum is pulled on the crankcase (block, oil pan, head/valvecover, etc). Any combustion fumes that pass the rings or oil vapors will be pulled into the intake and burned before being released to the atmosphere. The whole point of this is reduced emissions. Under boost, a check valve closes to prevent pressurizing the crankcase, which is bad, see next section.
The valve cover vent going to the intake pipe is to let excess pressure under boost from blowby be released. It's released into the intake to ensure it is burned completely before entering the atmosphere, again, for emissions. Positive pressure in the crankcase is always bad. It increases the density of the air in the block increasing pumping losses (don't forget the bottom sides of the pistons also have to move air around ). It also makes it much more difficult for the piston rings to make a good seal, compounding the problem. High HP race motors can get some good blowby at high boost. This is what pops the dipstick out on some cars. I run 2 valve cover vents, others have run more. Some race cars run electric or belt driven vacuum pumps to pull a stronger vacuum on the crankcase. A bad PCV valve can also allow manifold boost to enter the crankcase, raising pressure, and essentially creating a boost leak since the VC vent goes to the intake pre-turbo. High HP cars should remove this valve to be safe, or at least replace it often. A brake boost fitting from an intake manifold will thread right into the PVC port (1/8th BSP threads) allowing for another 3/8th vent line to be attached. This is not legal for emissions though. Another thing to note is that venting the valve cover to atmosphere will bollix your fuel trims. DSMlinkers, forget about using global and dead time to adjust trims in this configuration, unless you don't mind compensating for WOT with the sliders. This is the reason the factory runs this line to the intake post MAS.
Hope this helps.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-20-2006, 02:16 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: stupid question
Kevin I still think you should write a book. You are one of the most knowledgable DSM'ers that I know of.
95 Talon TSI AWD
97 Eclipse GST
Old 05-20-2006, 02:23 AM
AF - Advisor
Re: stupid question
I would, but DSMers are too broke or too cheap to make it worth my time Someday I'll start adding this stuff to my website, which is the next best thing, even though it actually costs me money And thanks for the kind words, as usual.
Kevin Jewer
Old 05-20-2006, 02:55 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: stupid question
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-21-2006, 04:23 AM
ned032002's Avatar
Re: stupid question
Kevin, I am forever your slave. *worships Kevin* lol
Old 05-21-2006, 10:23 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: stupid question
just to throw my two cents in here you can buy a really cheap fuel filter at autozone, (I think it's the 3/8 inlet/outlet) and use that as a catch can. Just cut that rubber line and line up the arrows on the fuel filter, make sure it goes the right way. It's like 1.50 and works just as well as any catch can. I replace it every oil change.
now - 2000 civic
soon - 2002 is300
Old 05-21-2006, 10:42 PM
Thor06's Avatar
Jizzed In My Pants
Re: stupid question
I made one out of a 4" section of 2" PVC, two end caps, two of those inlet things (like on a MBC), and a ghetto plastic valve (to let the oil out). I thought it was pretty sweet, it was only like $8.
