Old 05-18-2006, 03:26 PM
countrygirl22 countrygirl22 is offline
Replacing lifters...is it worth it??
Hey guys!
Yes, another problem with the Blazer. Never did get the 4wd fixed...oh well, no more snow to deal with!
Anyways, I have a 1995 Blazer LT with the 4.3L Vortec in it with 189,000 miles. About a month ago it started knocking pretty bad. I had a mechanic look at it and he feels one of the lifters is bad. He estimated it to be a $1000 fix. I have a read some posts on here about lifter problems but am wondering how hard of a fix it would be to do it myself. (Well, my dad would be doing most of the work!!) Would if it be a tough fix, any pointers?
Also, I came across a lot of negative stuff about Fram oil filters. YIKES... I have changed oil plenty of times and used those!! How bad is that?
Any suggestions would be very helpful! Just not sure if we should take on this task or not!
Thanks in advance!
Old 05-18-2006, 09:05 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Replacing lifters...is it worth it??
#1: Are you using Fram now?
#2: do you have a lifter claking noise? Or a rod knock.
#3: What oil Are you using?
I have a 1995 and can help you directly, the #1 thing about this engine is that you need 4.5 quarts to fill the oil up.
Do NOT go by the dipstick, full on the dipstick is 1/2 quart overfilledd and you will be having the crank slap the oil, introduce air into it which will migrate to the lifters and collect causing the noise.
I used to have the valve train noise until I Auto-RX's the truck, and only used the right volume of oil instead of filling it to the full mark on the dipstick.
I suggest Auto-RX, worked great on m truck. And the stuff it removed plugged a 10,000 miles capable oil filter in 1500miles.
www.auto-rx.com
At full, the oil should be up to3/4 in the cross-hatched area.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-19-2006, 07:46 AM
Thanks for the reply BlazerLT.
I stopped using Fram about a year or so ago, now use a NAPA brand and oil I believe is Citgo. I have had a couple different people listen to it and they all seem to think it is lifter noise. It is a pretty loud clanking noise. I have always filled it with 4.5 quarts... the dipstick half the time doesn't tell you anything even close to being right.
I think the Auto-RX would be worth a try. Would you suggest using a synthetic oil as well?
Old 05-19-2006, 09:28 AM
SComp23 SComp23 is offline
If you switch to synthetic you may be switching out a lot of your seals also. It is not guaranteed, but it is a possibility with switching over a high-mileage engine to synthetic.
Old 05-19-2006, 09:37 AM
redwheeler's Avatar
redwheeler redwheeler is offline
that is totaly un true synthetic oil will not cause youre seals to fail it will just elmnate the junk that was stoping up the leak
and yes i am a ASE Master Auto Technician
1996 chevrolet silverado 5.7L 4x4
nothin but a k&n for now i just got it
Old 05-19-2006, 10:05 AM
Where did I say the seals would fail? I didn't. The better cleaning property of the oil along with the smaller molecular structure can allow oil to seep out of seals by cleaning away the build up caused by oil sludge and dirt. When this happens you have to switch out the seal. I never once said the oil would cause a seal to leak, only expose leaks that are already there, please read what I said before you jump on me. Thanks.
Old 05-20-2006, 09:46 AM
redwheeler's Avatar
im not jumping on you but i do beleve that this is saying that swiching to synthetic will cause a leak "If you switch to synthetic you may be switching out a lot of your seals also."
Old 05-20-2006, 10:38 AM
OverBoardProject OverBoardProject is offline
Banned
I've seen synthetic oil stop more leaks lately than start them. It aeast to me that the seals just don't do their job when they're full of crud
BlazerLT, is there a store that you know of which sells Auto-RX on the shelves in Canada?
Old 05-20-2006, 01:25 PM
Depends on what synthetic you use, Mobil 1 does not have nearly as many additives used to swell seals as they used to. So when I personally switched to synthetic, oil leaks started. Say what you wish, but if you switch over to synthetic, and your oil starts to leak, the synthetic has removed the gunk from the seals, and the seals are now leaking.
Old 05-20-2006, 02:15 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Originally Posted by countrygirl22
Hey guys!
Thanks in advance!
If it is a deep knock you may have other problems.
Lifters like woodpeckers do more pecking than knocking.
If you have a lifter noise pull the valve cover and have a look.
A rocker bad or lose or push rod bad will give you a noise to.
Does it do it on start up or all of the time?
MT
MT
Old 05-20-2006, 02:33 PM
MT-2500's Avatar
AF - Advisor
Hey guys!
Thanks in advance!
Lot of pros and cons on oil .
The main thing on the oil is to keep it changed regular and use a good oil filter to keep it clean.
Oil synthetic or regular is good and will last beyond the recommended oil changes but it gets dirty. The dirt is what does the damage to lifters and engines.
On oil filters here is a couple of links to a oil filter study.
http://minimopar.knizefamily.net/oilfilters.html
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
mt
MT
Old 05-20-2006, 02:40 PM
solarflareq solarflareq is offline
I had the same thing sounded 100% like a lifter.. ended up conrod bearing which seems to be a weak point in the engine.
1.5Ltr's Gas in oilpan from leaking fuel regulator
manny manny hours later after teardown to conrod's =life time of 4.3L vortec experiance
and verry glad I tossed all the bullets for my guns out before starting the project.
Now i just need a T-SHIRT
Old 05-21-2006, 02:24 PM
BlazerLT's Avatar
AF -Advisor
Synthetic will not cause leaks period, I switched to synthetic at 130,000 miles and no one drop, actually, the oil cooler lines also stopped leaking.
The Auto-RX has to be used with conventional oil for it to work. Follow the directions to the letter on the site.
Also, there are no Canadian Distributors. I per sonally bought mine from the site.
Old 05-22-2006, 08:40 AM
Hey guys, thanks for all the replies. My Blazer was driven home after the mechanic had looked at it this weekend and about a mile from home it lost all power and the noise which we thought to be lifter noise became much louder. Could bad lifters explain the loss of power, or (much to my dismay) are we talking a lot more damage here then just lifters? It makes constant noise. When I first noticed it a while back it was more of a constant ticking noise. Now, it is a pretty loud.
Old 05-22-2006, 09:39 AM
Banned
It's possible for a lifter to colapse altogether, which could cause a power loss. Although I've never seen it happen.
Someone else might have another idea what it could be.
