Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 05-18-2006, 02:18 PM
roamin_shadow roamin_shadow is offline
Need Help w/88 Fiero BAD!!!!!
Have a problem that is weird. Car lost all power just quit running no lights radio etc. Then 20 minutes later the lights radio etc came back but the engine wont crank over two or three times then its like the battery is dead - just clicks, except the lights n stuff still work. Alternator, starter and battery is good. What next? Please reply quickly. Much appreciated.
Old 05-20-2006, 03:25 PM
jeremey m jeremey m is offline
Re: Need Help w/88 Fiero BAD!!!!!
roaming shadow
did you check your alternater belt?i"ve owned 3 gt"s this happend to 1 of them turned out to be a snapped belt.hope it"s nothin major cuz they are great underated cars.(the gt"s)
Old 05-21-2006, 08:46 AM
Not the alternator belt - I've had it off along with the starter - had them checked to see if they were bad. If I hook a batt charger up then it cranks longer but then it will just click again. You can see all the lights and accessories dim when the engine cranks. It's like there is a power drain. Thanks tho I appreciate the help.
