Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '06+ Civic
Old 05-18-2006, 02:03 PM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Post 2006+ Civic Recalls
Here is a list of recalls/service bulletins.
This thread is real old I will try to update it with new information.
Fell free to add recalls and service bulletins for the 06-07 models you know of. Also post up an useful information regarding known issues and there resolutions as wells as issues you think are relevant to other members.
I'll try to get this stickied for future reference.
Thanks
Here is a good site where you can search TSB and recalls for the Honda or any make
http://www-odi.nhtsa.dot.gov/
Gas pedal
Make : HONDA Model : CIVIC Year : 2006
Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.)
NHTSA CAMPAIGN ID Number : 05V509000 Mfg's Report Date : NOV 02, 2005
Component: VEHICLE SPEED CONTROL:ACCELERATOR PEDAL
Potential Number Of Units Affected : 25298
Front airbag sensor on coupes
NHTSA CAMPAIGN ID Number : 05V572000 Mfg's Report Date : DEC 22, 2005
Component: AIR BAGS:FRONTAL
Potential Number Of Units Affected : 12756
No amber reflector on headlights
Manufacturer : ANZO USA, INC.
NHTSA CAMPAIGN ID Number : 06E023000 Mfg's Report Date : MAR 09, 2006
Component: EXTERIOR LIGHTING:HEADLIGHTS
Potential Number Of Units Affected : 97000
TSB - Technical Service Bulletins
Service Bulletin Num : 1205
Date of Bulletin: DEC 16, 2005
NHTSA Item Number: 10018868
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary:
TRANSMISSION GRINDS AT SHIFTS, SKIP SHIFTING.
Service Bulletin Num : 1105
Date of Bulletin: NOV 16, 2005
NHTSA Item Number: 10018257
Component: ELECTRICAL SYSTEM
Summary:
ACCESSORY POWER SOCKET INOPERATIVE.
Service Bulletin Num : 09012005
Date of Bulletin: SEP 01, 2005
NHTSA Item Number: 10018474
Summary:
NEW SOFTWARE FOR HDS: VERSION 2.001.01.
NHTSA Item Number: 10018477
Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
Summary:
WHY A PC CARD WONT PLAY IN THE AUDIO UNIT. APPLIES TO '06 CIVIC EX AND SI MODELS WITH THE NAVIGATION SYSTEM.
NHTSA Item Number: 10018479
Component: SEAT BELTS
Summary:
NEW SEAT BELT REMINDER LOGIC FOR '06 MODELS. APPLIES TO '06 ACCORDS, '06 CIVICS, '06 PILOTS, AND '06 S2000'S.
NHTSA Item Number: 10018480
Summary:
NEW IMMOBILIZER SYSTEM ON '06 CIVICS.
NHTSA Item Number: 10018482
Summary:
TAKING THE MYSTERY OUT OF THE MAINTENANCE MINDER SYSTEM.
Service Bulletin Num : 06007 Date of Bulletin: FEB 17, 2006
NHTSA Item Number: 10020138
Component: ELECTRICAL SYSTEM: INSTRUMENT PANEL
Summary:
SRS INDICATOR STAYS ON, AND DTC 86-16 IS STORED. *TT
Service Bulletin Num : 506 Date of Bulletin: MAY 01, 2006
NHTSA Item Number: 10020038
Component: STEERING:HYDRAULIC POWER ASSIST:PUMP
Summary:
FLUID LEAK AT POWER STEERING PUMP. *TT
Service Bulletin Num : 06031 Date of Bulletin: JUN 09, 2006
NHTSA Item Number: 10020156
Component: SEATS
Summary:
FRONT SEAT CLICKS WHEN SLIDING OR DOES NOT SLIDE. *TT
Honda Civic Recall # 06V326000- VISIBILITY:GLASS, SIDE/REAR
Component:
Summary:
ON CERTAIN 2-DOOR PASSENGER VEHICLES, THE REAR WINDSHIELD OR REAR QUARTER GLASS PANELS DO NOT PROPERLY ADHERE TO THE BODY OF THE CAR DUE TO IMPROPER WINDOW OPENING PREPARATION.
Consequences:
THE REAR WINDSHIELD OR REAR QUARTER GLASS PANELS MAY BECOME LOOSE, RATTLE OR LIFT FROM THE WINDOW OPENING OR SEPARATE FROM THE WINDOW WHILE DRIVING INCREASING THE SAFETY HAZARD TO TRAFFIC.
Remedy:
DEALERS WILL REPAIR THE VEHICLE BY REMOVING THE GLASS, PROPERLY PREPARING THE WINDOW OPENING, AND REINSTALLING THE GLASS. THE RECALL IS EXPECTED TO BEGIN DURING LATE SEPTEMBER 2006. OWNERS MAY CONTACT HONDA AT 1-800-999-1009.
2006 HONDA CIVIC EXTERIOR LIGHTING:HEADLIGHTS
Recall Date:
MAR 13, 2006
Summary:
CERTAIN ANZO COMBINATION HEADLAMP ASSEMBLIES SOLD AS REPLACEMENT LAMPS FOR USE ON CERTAIN PASSENGER VEHICLES. SOME COMBINATION LAMPS ARE NOT EQUIPPED WITH AMBER SIDE REFLECTORS WHICH FAIL TO CONFORM TO FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.”
Consequence:
WITHOUT THE AMBER REFLECTORS, THE VEHICLE WILL BE POORLY ILLUMINATED, POSSIBLY RESULTING IN A VEHICLE CRASH.
Remedy:
ANZO WILL NOTIFY OWNERS AND REPLACE THE HEADLAMPS FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING MARCH 2006. OWNERS MAY CONTACT ANZO USA AT 909-468-3688.
[Source: The Detroit News]NHTSA CAMPAIGN ID Number : 07V399000
Mfr's Report Date : AUG 30, 2007
Component: WHEELS
Potential Number Of Units Affected : 182756
Summary:
ON CERTAIN VEHICLES, THE WHEEL SPEED SENSOR HOUSING USES AN O-RING SEAL TO PREVENT LEAKAGE TO OR FROM THE WHEEL BEARING. IF ASSEMBLED IMPROPERLY, THE O-RING MAY NOT SEAL PROPERLY ALLOWING WATER TO ENTER THE WHEEL BEARING AND EVENTUALLY CAUSE DAMAGE TO THE BEARING, ESPECIALLY IN AREAS WHERE USE OF ROAD SALT IS PREVALENT. IF THE DRIVER CONTINUES TO DRIVE WITH THIS CONDITION IT IS POSSIBLE FOR THE WHEEL BEARING TO BECOME LOOSE, WHICH COULD CAUSE THE BEARING TO FAIL.
Consequence:
THIS COULD CAUSE A WHEEL TO FALL OFF OF THE VEHICLE, POSSIBLY RESULTING IN A CRASH.
Remedy:
DEALERS WILL INSPECT THE REAR ABS SENSORS AND WHEEL BEARINGS FOR DAMAGED PARTS AND REPLACE THEM FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT SEPTEMBER 17, 2007. OWNERS MAY CONTACT HONDA AT 1-800-999-1009.
03.IS300.MT.LSD. 'Supra in Training'
Old 06-01-2006, 10:27 PM
lorunner lorunner is offline
Re: 2006 Civic Recalls
Half of them aren't recalls.
they got service bullitens mixed up with recalls
Stop asking me about radio codes I cant get them anymore!!!
Old 01-07-2007, 10:38 PM
VW816 VW816 is offline
so is there a recall on the manual trannys for 06 civic si because i have been hearing a slight grind shifting into third gear like it is a bad synchronizer
