Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-18-2006, 12:00 PM
97gs-t teamrtv 97gs-t teamrtv is offline
Send a message via AIM to 97gs-t teamrtv Send a message via MSN to 97gs-t teamrtv Send a message via Yahoo to 97gs-t teamrtv
Antifreeze hoses
Ive done some searching but to no avail of such a specific answer. I have a second coolant leak on one of the lower coolant hoses. Ive replaced one already a few weeks ago. My question is should you replace all these hoses with new clamps when taking the turbo/manifold/o2 housing out? or can you just reuse them. Are these hoses a common problem? I have not read any complaints though.
97 gs-t: Guages: boost, oil pressure and temp, water temp and volts. AEM cam gears, short throw shifter, hks ssqv, injen intake, brembo drilled rotors, akebono ceramic pads, sportline springs & koni ajustables, Strut bars: front, rear and lower rear tie bar. Evo III manifold and o2, megan downpipe, Apexi N1 catback, 16g, 190 fuel pump and FMIC.
Old 05-18-2006, 01:09 PM
Fallenfantasies Fallenfantasies is offline
Re: Antifreeze hoses
I reused mine but if yours look bad or have slits in them then replace them
Old 05-18-2006, 02:58 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
I reused the same clamps, no biggie, they're metal, they're fine. I also noticed a huge bubble starting to form on my upper radiator hose, so I replaced the upper and lower, pretty common problem.
now - 2000 civic
soon - 2002 is300
Old 05-18-2006, 08:15 PM
showstopperz's Avatar
showstopperz showstopperz is offline
When I installed my hard intake pipe i must have moved one of the coolant lines that run under my manifold. Cuz the next day that line had a hole burned into it!! So i had to replace that one.
1998 spyder gst 5 speed
2007 Mazda SPEED3
Old 05-18-2006, 11:27 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I know greddy makes a braided stainless kit for about $your soul. I bet some other companies sell them too i've just never really looked into them.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-19-2006, 02:51 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
The rubber ones work fine, and they aren't expensive at all.
I replaced all the clamps in my gsx considering they are way old. But if your clamps look and function fine, no reason to replace them,
1991 GSX 2.3 Stroker
