Old 05-18-2006, 10:12 AM
Gnomonic Gnomonic is offline
95 Lesabre Coolant Leak at Throttle Body
Hey,
I've got a reasonably serious coolant leak coming from somewhere around the throttle body.
Any suggestions on how to start addressing this?
What is in there that could be busted/cracked?
Any recommendations on handbooks? Chilton's better than haynes, for example?
Thanks.
Old 05-18-2006, 11:05 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: 95 Lesabre Coolant Leak at Throttle Body
Hello
I feel that Chilton's is better than haynes. A factory manual beats them all.
Sorry I don't know what to tell you about the leak without looking at it.
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 05-18-2006, 11:39 AM
Thanks Dan.
With a little further research (which I should have done earlier) this appears likely to be the plastic intake problem due to a hot EGR pipe.
Unfortunately the fixes I've found seem geared toward VIN K engines.
I don't have any K in my VIN.
It appears to be the "L" engine.
Is the series I the "L" and series II the "K" or is that too easy?
Old 06-01-2006, 09:42 AM
taser1984 taser1984 is offline
Send a message via AIM to taser1984
Last weekend I fixed that leak (at least it sounds like it) on my 1994 (it's a vin L too). Searched all over and found the same egr info you did, but since that was all for series II engines, I knew that it wasn't the same. (I think the egr leak goes inside the engine.)
There's a gasket between the throttle body and the intake manifold. There's a small coolant passage there that "improves cold driveability." Mine was leaking at that gasket. Took less than 2 hours to fix (with no real advance info) and parts were $5 in stock at a local AutoZone.
If you need more info on this get in touch with me. I took pictures while I was doing it and can give you step-by-step directions.
Old 06-01-2006, 12:03 PM
Taser,
This is great information.
I'll definitely look into changing this gasket before I dump a bunch of money into buying a new intake manifold.
I'll love to see pictures...can you post them here?
Do you have the part number handy?
Thanks very much.
Edit update...found the Throttle Body Base Gasket at Autozone.
I got it in there early this morning. No leak so far.
But my damn TPS error codes appear to be back and the car is stalling again.
