Old 05-18-2006, 08:53 AM
aorozco2's Avatar
aorozco2 aorozco2 is offline
have electrical problem
so 2 weeks ago my right headlight dies, so I think that is just the light right. so last night I go turn my car on and the try to turn my headlights on and the dashboard doesnt light up and the headlights just pop up and dont turn on. what could be wrong?
Wheels/brakes/Suspension:
Hawk HPS Brake Pads
R1 concepts cross drilled and slotted rotors
Megan Racing "Street Series" Coilover Kit
Adjustable control arms
adjustable toe arms
exhaust:
2.5" test pipe
2.5" cat back (angled out)
Misc.:
Short throw shifter
Soon to come:
TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc...
Old 05-18-2006, 10:19 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: have electrical problem
sounds like a fuse. check all the fuses, located driver side under the dash above your left leg.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-18-2006, 06:32 PM
aorozco2's Avatar
is definetly none of the fuses.
Hawk HPS Brake Pads
adjustable toe arms
exhaust:
2.5" test pipe
Misc.:
Short throw shifter
Soon to come:
Old 05-19-2006, 01:52 PM
Igovert500's Avatar
blue + red light magnet
Are your parking lights in the rear coming on? It might be the light switch, or some short in the lighting circuit.
Being that the one headlight went out 2 weeks ago, I'd guess that would be the bulb. But with nothing working, I'm guessing they are all on the same circuit and something is wrong with it. Try a search on 3si, see if anybody has had similar issues.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-19-2006, 04:08 PM
aorozco2's Avatar
the parking lights dont come on and the when I turn the headlight switch on the only pop up but dont come on.
because the dash lights are off (and also the 3 gauges in the middle are off), but only the brake, abs, turnsignals, etc. light up when I turn on the car.
Hawk HPS Brake Pads
adjustable toe arms
exhaust:
2.5" test pipe
Misc.:
Short throw shifter
Soon to come:
