Old 05-18-2006, 06:42 AM
dk05 dk05 is offline
Dropping Fuel Tank?
What is the minimum that needs to be done to drop the fuel tank in a 3rd gen? I want to put an aftermarket fuel pump in and need to figure out if I should try doing it myself or take it to a garage and work on it there. I do not want to cut any holes in the car either. Thank you.
Old 05-18-2006, 08:04 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Dropping Fuel Tank?
You have to drop your exhaust, whole rear end and finally have your car up high enough so that the tank is able to fall down nicely and be pulled out.
Old 05-18-2006, 01:07 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
you need to take down the heat shields, then the subframe connector thing that is attached to the differential, then the straps holding the tank up, then you gotta fight to get the tank out.. thats probably the hardest part cause the filler neck gets stuck. it does not drop right out.. to make it easier, you should probably have somebody to help you out so they can manuever the tank under the car while you try to get the damn neck unstuck.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 05-18-2006, 01:49 PM
bag91's Avatar
bag91 bag91 is offline
You need to remove the rear end????
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 05-18-2006, 01:57 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
and be careful not to crack the filler neck when you put the tank back in.
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 05-18-2006, 04:24 PM
Is eating.
Almost.. look at what AFI said thats almost there.
Old 05-19-2006, 01:18 AM
Thanks guys. My Chilton's is very vague on the fuel tank removal (actually it has served me no purpose except for torque specs as it does not even have a wiring diagram for my specific car.... not worth much, LOL). It sounds like alot of you have had the pleasure of doing this once or twice. Sounds like this is gonna be a fun job......
Old 05-23-2006, 12:46 PM
skyluslondon's Avatar
skyluslondon skyluslondon is offline
well known for cracking isnt it? or was that just a recall part for the 91s?
Old 05-23-2006, 12:54 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
That's odd, atleast mine made a little pad for my head and padded the tank when decided it was ready to come down.
Old 05-23-2006, 02:24 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
or you can pull a few back panels out pull the carpet up and cut a hole in the metal to get to it
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 05-23-2006, 02:49 PM
SG007's Avatar
that is so ghetto lol not to mention cutting through METAL on top of a GAS TANK.
kaboom hahahahaha
Old 05-23-2006, 05:51 PM
Is eating.
kaboom hahahahaha
Not really so ghetto when..
1. it saves ALOT of time
2. Stops you from getting a major headache
3. Makes it seriously easier to get it out and back in
And no it doesnt go kaboom.. you're not cutting the gas tank itself.
Old 05-24-2006, 08:48 AM
wrightz28's Avatar
Yeah but when tell some yahoo (not you dk05) that cutting the trunk is the way to go and they use a damn sawzall with a 10" blade when there's 2" tops clearence between the floor and tank, well you do the math.
Cutting IS ghetto. And especially on a car that has inherant structural integrity from the day it rolled off the line.
Old 05-24-2006, 11:16 AM
LOL... I know it saves a lot of time but I doubt I will have to change the pump more than once. It seems like I am working on the car alot more than I am driving it. Not only that but the car only has 54,000 on it and I hate to ruin it by cutting holes just to save time. Actually that is the reason I don't like taking my car to shops because alot of them will just cut and pry and do whatever they can to save time then charge for the normal time.
Old 05-24-2006, 11:55 AM
wrightz28's Avatar
Yep, it's official boys, he owns a Camaro
