Old 05-18-2006, 02:47 AM
JunkTitleGolf's Avatar
JunkTitleGolf JunkTitleGolf is offline
Over heating amp
Ok well, my amp overheated tonight and went into thermal protection and shutdown. But the thing is I was only pushing one sub and had my bass boost all the way up and my hu was at 20 out of 30 (or so). Is there anyway to stop this from happening again. Currently the amp is mounted on the back of my rear seat and folded down. I have a port that is blowing over it but I guess that isn't enough. Also my amp doesn't have a fan on it...strange.
1995 VW Golf
Cold Air Intake
Cat delete
Full straight pipe exhaust
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Cerwin Vega Vmax sub
Old 05-18-2006, 12:25 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: Over heating amp
turn the bass boost down.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 05-18-2006, 12:27 PM
bjboertje's Avatar
How many watts is the amp? Mine has no fan and is 1500 rms and doesn't even get warm.
PA isn't that good.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 05-18-2006, 12:45 PM
I'm running it at 440 rms right now per channel and I'm only using one channel. Is there any mounting variates I could do, like raise the amp up so air pass under it or install a couple of fans nearby?
1995 VW Golf
Cold Air Intake
Cat delete
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Old 05-19-2006, 08:55 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the best mounting positions are straight up or the normal flat. Fans can help move a little more air over it.
Old 05-20-2006, 04:17 PM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
the fins really do work, it's not going to keep it ice cold, but sending some fan air through the fins will help that much more...
SELLING THE HONDA...
Old 05-20-2006, 11:00 PM
Audio Guy
my first thing in your case would be to find out why it is overheating so much. Either you have it mounted in a position that isn't allowing good cooling or you or running a low impedance load and running the volume up to max (in relation to the amp, not the headunit volume).
Old 05-21-2006, 10:44 AM
They suggest mounting my amp either horizontal or vertical. Mine is horizontal on the back of my rear seat. The seat is laying down. I'm running it at 2 ohms right now but the amp is 2 ohm stable in stereo mode. Could it possibly be that I am running at 2 ohms but since I only have one sub hooked up it isn't in stereo mode?
1995 VW Golf
Cold Air Intake
Cat delete
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Old 05-23-2006, 09:38 PM
Audio Guy
if you have the amp bridged, each channel is only seeing 1 ohm
Old 05-24-2006, 03:15 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
bass boost down, check your gains, check your impeadances, amps shouldnt need air moving over the heat sink if there is good ventelation unless it is a bad design.
Originally Posted by KickinAudio,May 24 2006, 07:18 AM
[snapback]182542[/snapback]
if these arent over heating yours shouldnt be either.
Old 05-24-2006, 06:59 PM
Well, my sub has dvc and they are each 4 ohms each. Lowest I could go would be 2 ohm each (right? I have pos on side a connected to neg on side b). I'm not bridged and I had a friend redo my gains and everything. Hasn't overheated since then. Well, that I can recall. My bass boost is about 3/4 or so. I adjust it to each song.
1995 VW Golf
Cold Air Intake
Cat delete
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Old 05-25-2006, 10:30 AM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
if you have one positive connected to the other negative, and the other two directly to the amp, then you are running the voice coils in series which would put it at 8 ohms. It seems like it would be difficult to overheat a 2 ohm stable amp with an 8 ohm load. I don't know what you did, lol.
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 05-26-2006, 01:42 AM
Maybe I have it the other way. I can't remember. I will check whenever I can. But it hasn't overheated for a while now.
1995 VW Golf
Cold Air Intake
Cat delete
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Old 05-31-2006, 08:40 PM
Audio Guy
basic accepted fact of engineering ....... lowering the operating temp of a device by 10 C (appx 18F) will double the items life span. So proper mounting and ventilation/ cooling is important.
Old 05-31-2006, 09:37 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
The most common causes of overheating are:
impedance too low (apparently not the case here)
bad mounting position (probably not the case here)
or bad clipping (with 3/4 bass boost and probably similar gains, this is the likely culprit)
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
