Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-18-2006, 01:49 AM
flip888 flip888 is offline
Ford 7.3l Powerstroke Turbo on a DSM
I know a guy who wants to put a turbo from a Ford Powerstroke 7.3 Turbo Diesel on his 95 gsx and i was wondering how hard it would be to get it to work and what power it could make on a dsm or if it would spool. The only thing i know about the turbo is that it has a 1.15 turbine housing and turbine wheel.
Thanks
Old 05-18-2006, 02:09 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Ford 7.3l Powerstroke Turbo on a DSM
You're talking about putting a V8 diesel truck turbo onto a 4 cylinder car motor....IF it fits up correctly, good luck getting it to work right. Not worth the effort IMO.
95 Talon TSI AWD
97 Eclipse GST
Old 05-18-2006, 10:59 AM
Black97GST Black97GST is offline
ummmm????? the 4 cylinder that comes in the car is already SQWISHED in the engine compartment............. good luck fitting a v8 TURBO DIESEL TRUCK engine in there..... it would be VERY HARD.... dont try it.......
Old 05-18-2006, 11:37 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Reading skills are essential...he just wants to take the turbo from the truck and put it on his 4g63.
You can't just slap on a MASSIVE turbo and boost the shit out of your car. You will need fuel and supporting mods. Read the FAQ page and go to www.vfaq.com and read up.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-18-2006, 12:56 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I dont think diesel turbos are the same as gas turbos. I wouldnt do it, just get a bigger normal turbo.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-18-2006, 08:36 PM
kjewer1 kjewer1 is offline
AF - Advisor
People run the cummins turbo diesel (dodge trucks) turbos in DSMs. The HX30 or 35 turbos are from these trucks. IIRC, when I looked up my truck's HX35 it was similar to a 60-1, or 35R. Airflow in the low to mid 60s. One company put a bolt on turbine housing on it. You can bet the AR on that housing is DSM appropriate though, a 1.15 is certainly not.
That thing will most likely lag like a bastard, and who knows how the turbo/car will have to be modded to fit it up. Not worth the effort at all IMO, considering the large selection of properly sized turbos available to us.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
