Old 05-18-2006, 12:10 AM
civic88dx's Avatar
civic88dx civic88dx is offline
NO brake lights!
i was replacing one of my tail light bulbs and i went to test it and realized that the break lights did light up at all. i press the pedal and they didnt light up. i check the fuse and everything else on that circut works. since i do not drive behind my own car, i dont know how long i have had no brake lights for.
what is wrong and how can i fix this?
Old 05-18-2006, 01:58 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: NO brake lights!
check your brake light switch. Its right off the brake pedal lever. every tine you depress the brake pedal, it hits a switch which tells the brake lights to go on. check for continuity (resistance) between the two wires that come off of the switch. With the pedal pressed, you should have continuity, a.k.a the resistance should drop to 0. With the pedal up, risistance should be high and no continuity
Edit: Also, are you sure you put in the correct bulb? And put it in properly? Goofy shit happens when the wrong bulb is used.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-18-2006, 01:00 PM
civic88dx's Avatar
im pretty sure i used the right bulbs. i looked up the bulb # at the autoparts store. i read in another thread that the break lights run through the same circut as the horn. i noticed that my horn stopped workin, so im guessing that just the fuse for the horn is blown
Old 05-20-2006, 12:28 AM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
you cant have high resistance and no continuity cause if the circuit is open then there can be no resistance cause it is not a complete circuit.
Old 05-20-2006, 01:54 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
He means that it will show a 1, or infinite resistance...as opposed to a 0 for a closed perfect circuit.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 05-21-2006, 01:04 PM
oh ok missunderstanding then i thought he meant something else.
