Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-17-2006, 10:33 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
Exclamation help again
i own a 92 tsi awd
well ive been posting alot lately, cause im trying to fix alot of problems.
first i bought this car as a project, i put a clutch in it and drove it for a while and all that but it was time for some serious fixing. i bought a brand new head, arp head studs a hks head gasket, a really nice engine gasket kit, a new return line, stainless oil feed line. timing belt kit, pistons rods the whole 9 damn yards.
now i get everything cleaned and bored and everything put it all back together torque every bolt to spec and everything. i fired it up for the first time yesterday and it ran good idled at like 800rpms and all that sounded good other than the normal lifter tick(yes i didnt upgrade yet). when i took it for a drive it ran shitty which i thought was the RFL i had on it. so i took it off and put my stock 1g back on and it ran better driving wise but still didnt seem to be good like it should be.
it doesnt feel like its runing 11lbs at all it feels like 3 at the most i feel no pull at all like it should. everything is new i checked all the clamps and hoses everything is good i cant find any leaks or anything. My boost gauge reads 11 lbs when i boost and my vaccum seems low at idle its only 12 or 13 which i thought it should be more.
now im sorry for the long boring post but im trying to get all my problems out there for any help or ideas. now i had to ghetto wire my fans cause i cant find anything wrong with them ive replaced everything. now my point on that is when i turn on my fans my idle drops like the load is too much. do you think my alternator is at fault cause its old and stuff but it keeps my battery charged but if i turn on anything the fans my lights it bogs my idle down.
thanks ahead of time and hope i can get ideas to help me fix these problems i really dont want to pay someone an outrageous price to fix it for me
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 05-17-2006, 11:11 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: help again
Did you do a boost leak test? I thought i heard something about the rings not seating properly during engine break in which results in lower compression. I'm assuming you're still breaking in the motor?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-18-2006, 04:05 PM
Re: help again
yea im still breaking it in ive barely put any time or mileage on it yet. i havent done a boost leak test the rain out here still hasnt stopped. i got a 3" gm maf sensor and im going to order the translator later today so i can run a blowthrough and vent my rfl
Old 05-18-2006, 11:30 PM
ez1286's Avatar
Re: help again
12-13 vac at idle is to high i ran ~20 and i think 18-21 is normal. I bet it's a boost leak.
Old 05-19-2006, 12:12 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: help again
Be sure to change the oil a lot. Search and you shall find the many different opinions on break ins.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-19-2006, 12:44 AM
ez1286's Avatar
Re: help again
hehe can't wait till i'm breaking my stroker in...
Old 05-19-2006, 12:59 AM
Re: help again
yea i figured that it was a boost leak like usuall, when it stops raining ill get my ass out there and do a leak down test and see what i can find.
breaking in your stroker isnt fun im freaking out about everything as you can tell. im worried about my vaccum not being high enough being im only running 12-13 when im just sitting there idling but im runing like 21 driving around when im not on the throttle. my electrical system dies down everytime i put a load on it and that bothers me
im just freaking out man. hell today i seen a decent civic all stock 5spd and i almost bought it.
Old 05-19-2006, 02:47 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: help again
Soungs like you have another problem witht he fan. Check the relays on the passanger side under the hood.
But aside from the lack of boost does the car run fine?
1991 GSX 2.3 Stroker
Old 05-19-2006, 10:10 PM
Re: help again
yea it runs alright but like i said as soon as i turn the fans on it idles a little less and somewhat rough
Old 05-20-2006, 11:04 AM
defiancy's Avatar
Re: help again
Well you can test the alternator by turning the car on and removing the leads of the battery. If the car stays running at idle your alternator is probably good. I mean are your lights dim or anything else?
Old 05-20-2006, 05:14 PM
Re: help again
yea the lights inside and out dim but it keeps the battery charged enough to start the car every time. i was thinking the battery could have a bad cell in it also
Old 05-20-2006, 05:42 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: help again
might want to run a shit turbo instead of the 16g i heard that the turbo gets all the crap left over from the rebuild.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
