Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-17-2006, 10:22 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Raisimg compression on 420a
Hey all;
As most of you know I'm rebuilding a head . 2 questions. They make different head gaskets that raise and lower compression, right? If so, do you think it would worth it to raise the compression on my 420a? Or should I build the bottom end too, then once I drop that in, then raise compression? I will eventually build up a bottom end, but not for a long time yet (unless I hit some kinda jackpot ). Opinions please. Oh, and remember my rule... no turbo
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-17-2006, 10:49 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Raisimg compression on 420a
I dont know if I would use HGs to change compression, you could get the head shaved a little bit to raise the compression, or just wait until you build the bottom end. Its really up to you
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-18-2006, 12:17 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Well, thicker head gaskets will lower compression, but the most you could lower by headgasket is by like .2 IIRC. You chould shave the head, but I doubt you'd be able to raise it much that way. Bottom end is basically it for rasing compression.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-18-2006, 12:24 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
If you rebuild the bottom end go for a stroker kit, I saw an ad for 420a stroker kits in sport compact.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
