Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 05-17-2006, 08:48 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
1990 88 Transmission delayed engage
Ok so i have a 1990 Oldsmobile Delta 88 Royale with the 3.8 L V6 auto tranny, and it seems every morning before work, my dad would shift out of park, and NOTHING HAPPENS, nothing at all! we have no idea wats going on, according to the service manual it can be low fluid, but the level is fine, and it could be some bad valve or something, but i dont know about that, does anyone have any ideas, i already replaced the Vacuum Modulator, and still no clue wat the problem is...
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
Old 05-30-2006, 08:09 PM
fourtwenty fourtwenty is offline
Re: 1990 88 Transmission delayed engage
I don't have time to find it, but search through my threads, I had a similar problem which was fixed by lucas transmission additive.
Old 05-30-2006, 10:13 PM
troy1 troy1 is offline
AF -Advisor
Bad internal seal in the trans. So its either overhaul it or just live with it.
Old 05-30-2006, 11:49 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
That particular transmission had some problems with spool valves inside the transmission leaking when cold. There's a fix for it, but unless you've never been into a valvebody i'd stay away from it..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 05-31-2006, 01:18 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
These transmissions usually start having trouble anywhere from 100k miles to 200k miles. In my case of a messed up tranny, it was easier to just get one from a junked engine (which I had conveniently in my garage) instead of trying to rip it apart and fix it.
However, Lucas may not be a bad idea to try before anything as drastic as a rebuild/replace/repair/etc. The only company's products that I fully trust what their labels say are Lucas and Seafoam, if that means anything to you.
But I'm kinda useless when it comes to the guts of a tranny since I haven't felt the need to rip one apart...yet....
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
