Old 05-17-2006, 08:44 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Amp Repair
I have a profile ca 600, its about 3 years old. Well some how in the movement from vehicle to vehicle about 4 times the rca jacks are pretty much screwed. Is there any way i could get a replacement set, im going to call profile to see the possibility. Im trying to do this as cheaply as possible since its such an old amp. Any feed back would be great thanks.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 05-18-2006, 12:32 AM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
Re: Amp Repair
the question is how good is your 2M skills...??
If you're really sic-wit-it then you should be able to pop it in no prob,
otherwise I wouldn't recommend you doing it and causing further damage.
SELLING THE HONDA...
Old 05-18-2006, 10:25 PM
Re: Amp Repair
If i cant do it my grand father has been working with electronics for 40 years, and my uncle does CNC repair so im sure that one of them can do any small circuit soldering if needed. Im good with electronics but i still have a lot to learn.
Cardomain
Old 05-19-2006, 05:12 PM
NAVY IC's Avatar
Re: Amp Repair
you got help, so you should try to repair the assembly.
if it's beyond repair...
contact your amp's manufacturer for a replacement rca jack.
if you can't find help there...
try to modify a universal rca jack assembly to fit into the same spot.
