Old 05-17-2006, 05:58 PM
DT2000GTP DT2000GTP is offline
Need Help Draining 2000 GTP Radiator
I am trying to flush my radiator but am not sure how to remove the radiator drain plug. Is it a white plastic plug located at the bottom on the driver's side? How do you remove it?
Old 05-17-2006, 06:00 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Need Help Draining 2000 GTP Radiator
You do not remove it and be careful not to break it. Take the end of a 1/4" drive rachet or handle. Insert and then turn about 1/4 of a turn counterclockwise. Coolant will start draining out.
Timeslip 08/12/06
AF Community Guidelines
Old 05-18-2006, 09:26 AM
KX2000GTP KX2000GTP is offline
HAHAHA, I never knew that...I always grabbed it with a pair of needle nose and twisted
