Old 05-17-2006, 06:58 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Sea-foam
Will using Sea Foam once a week in the intake ruin anything?? Cause Thats what im doing. 3 weeks now.
http://jowulf.deviantart.com/
Old 05-17-2006, 08:54 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Sea-foam
No reason to do it more than 2 or 3 times a year hun....
1/3 down the intake, 1/3 in the gastank, and 1/3 in the crank case 500 miles before an oil change..
Old 05-17-2006, 08:56 PM
Cloud Strife Cloud Strife is offline
Re: Sea-foam
Now will Seafoam interfere with AutoRX is the question.
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Old 05-17-2006, 09:02 PM
rlith's Avatar
Re: Sea-foam
It really shouldn't, but additives should be "added" sparingly
Old 05-18-2006, 08:03 PM
GirlBear's Avatar
Re: Sea-foam
im on my 2nd MAF and 2nd K&N filter. 02's are reasonably new. but it seems every week or so im loosing power. drives real slugglish. when i step on the gas pedal from a stop it diesels. like the cars did in the eighties when you turned them off. But pour in some Sea-Foam. use carb and choke cleaner with some Q-tips on the MAF. Bada Bing Like new again peppy very responsive. "passing" Power. 10 days later slow and shitty like an old dog. What gives?????????
Old 05-18-2006, 09:57 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Sea-foam
Yes it will.
Auto-RX requires you not to add anything else to it to thin it out.
As for seafoam, one can in the engine per year is all your need.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-18-2006, 10:54 PM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Re: Sea-foam
Sounds like maybe your filter is over oiled and gumming up your MAF.
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 05-18-2006, 10:58 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Sea-foam
That is a odd combination there Girbear.
Which one is helping it or doing the most good.?
The maf sensor clean or the sea-foam.
Any check engine lights?
Do you have acess to a engine scanner or fuel pressure gauge.
How is that fuel filter?
Go easy on the q-tips and.
Also go easy on the oil in the K&N filter. It is hard on maf sensors.
They make some maf cleaner in a spray can now that works good on clean them.
MT
MT
Old 05-19-2006, 12:36 AM
GirlBear's Avatar
Re: Sea-foam
check engine light is always on. It needs a screen saver lol. Im thinkin Fuel filter,Plus maybe Catalitic converter? I have plenty of time now. Plus the Blazer is leaking oil again like its a regular function. its coming from mid block passenger side. followed the wetness to this location. I cant see exactly where cant pin point it.
Old 05-19-2006, 01:41 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Sea-foam
the maf is being clogged up with oil from the cotten filter
Old 05-19-2006, 01:53 AM
BlazerLT's Avatar
AF -Advisor
Re: Sea-foam
Girlbear, why are you not going to get the codes check to find out what is wrong then?
Old 05-19-2006, 10:43 AM
GirlBear's Avatar
Re: Sea-foam
Im hard headed. But yeah Ill do that. Right after I do something about my dead battery. DOH! Went out this morning 9ish, DEAD! raining. ill wait til it stops.
Old 05-19-2006, 11:51 AM
MT-2500's Avatar
AF - Advisor
Re: Sea-foam
10-4 there Girl bear
Like BlazerLT says the codes may pinpoint the problem.
If you can a code post the no back.
And yes fuel filter is first thing to check.
If oil leak is on the side check that valve cover gasket.
If on the rear try a mirrow back there.
Also they make a dye to oput in the oil for hard to find leaks.
Good luck
MT
MT
