Old 05-17-2006, 03:58 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
I'm dangerous when I'm bored...Another center shift mod
So today I was given a 2000 Envoy Center console and shifter to play with (and keep of course)...Install was easy as I had the necessary mounts in place from my Column shift to center shift mod. This console is similar to the Jimmy Diamond Edition center console.
The center console is pewter/gray which is the same color as my dash, and the carpet on the side of it was nasty...So after thinking about it, I decided to install it. I taped off the plastic and dyed the carpet black to match my truck carpeting. The wood grain trim will be sanded down this weekend and sprayed gloss black and several layers of clear-coat. The front portion that goes under my dash will be wrapped in black leather to flow the design into my leather seats (so don't worry about that cut out portion in the 1st two pictures)
The shifter knob is very different from the regular center shifter. The release is in front, the button shown on the side is for shift points in the envoy (essentially the tow/haul switch). I wired that to kick on my amp (it's a momentary pulse switch). The rear controls I already have the diagrams for, so i will be wiring it to allow dvd and volume control of the AVIC-Z1 I have in the dash. The power socket is active an the headphone jacks are as well...(though I don't know why I did them as i have wireless headphones all over the car)
I removed the 6 disc gm changer (made by clarion) that was in the front as I have a 12 disc dvd/cd changer in the cargo area and I really didn't want the hassle of adding that unit. I did keep the face plate as you can see in the pictures, and I will probably mount some sort of switches behind the door (it's a push to open/close door)
Some of you may like it, some of you may not... You can see all the interior pics at www.pghconsulting.net/teal and see how the coloring flows in the truck...
Let me know what you think!
On to the pics!
Here is a basic shot, with nothing open...But as you can see the bottom right portion of my pewter dash, it matches, as does the black carpet...
Here is a shot with the cup holders open...(Much more space then my normal center console cup holders, and the hide!)
And a shot of the rear... As I said above, I will be wiring the controls into my AVIC-Z1
Old 05-17-2006, 05:14 PM
OverBoardProject OverBoardProject is offline
Banned
Re: I'm dangerous when I'm bored...Another center shift mod
Rlith, I should get you a Plane ticket to Kelowna the next time that your bored and talk you into working on 1 of my street rods
Old 05-17-2006, 08:40 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
I vote you keep the wood grain.
Then come over to my house come on i live 6 hrs max away and do up some doom a flitchys in the cutlass.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 05-17-2006, 10:05 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I am thinking he comes to my house, fixes the issues with my Blazer and then he helps me pump the lake out of my basement!!!!!!!!!! By the way, nice mod!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 05-17-2006, 10:31 PM
Banned
BlazerBoy, when did you get the indoor swimming pool installed? LOL
I hope that you weren't one of the people that got flooded out the last little while.
Old 05-18-2006, 09:24 AM
joeuser742 joeuser742 is offline
Oh man, I wish I had the time to do things like this. I'm too busy fixing my darn Blazer, I have no play time.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 05-18-2006, 10:09 AM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
damn Rick... plenty of goofing off time on your hands. looks great.
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 05-18-2006, 10:30 AM
I live in Peabody MA, I am sure you guys saw it on the news!!!! Peabody flooded the worst in MA.
K&N Air Filter
Old 05-18-2006, 10:33 AM
Banned
Sorry to hear about that man, wish that we could send Rlith over to give you a hand with your basement hehehehehe (sorry Rlith I had to)
I hope that it's only really your basement then that needs the work done.
Old 05-18-2006, 11:15 AM
Is that why you havent been able to get on AIM? i wanted to ask if ya owned a boat or someone that did cuz i was wondering.
Heres to sunshine in MA too bad it couldnt have flooded Fenway lol
Old 05-18-2006, 11:50 AM
HAHA it did flood Fenway!!! But we have been playing in Baltimore. Well I am moving into a new home which also took on water do to this storm but as soon as we move in I am putting in a french drain.
K&N Air Filter
Old 05-18-2006, 03:53 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
typical engenere
Old 05-18-2006, 06:04 PM
rlith's Avatar
Nah, just took the afternoon off...(Rank hath it's privleges )
Old 05-19-2006, 10:21 AM
I want updates.
I want to see that v8 under the hood too.
Updates now.
Old 05-19-2006, 10:36 AM
rlith's Avatar
Originally Posted by s10blazerman4x4
I want updates.
Updates now.
V8 isn't in yet... When I go on vacation I'm gonna try to do it...
