Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 05-17-2006, 12:12 PM
bluelogic bluelogic is offline
30K - Service for 2005 Ford Focus ZX4
Hi,
Can I do the 30K service for my car? This is what the book requires
1. Change engine oil and replace oil filter - Done
2. Inspect brake pads/shoes/rotors/drums, brake lines & hoses, parking brake - Done my dealer due to brake noise
3. Inspect engine cooling system and hoses
4. Inspect exhaust system and heat shields
5. Inspect steering linkage, suspension, and if equipped driveshaft and ball joints
6. Inspect tires for wear and rotate - Done by dealer
7. Replace engine air filter - Done by me
8. Replace fuel filter* - I can do it
9. Replace cabin air filter, if equipped - Don't have one
10. Inspect automatic transmission fluid level, if equipped with dipstick - Done
So as you can see I can replace the fuel filter for $20.00 and would have done all the replacement service. So why do I need to pay $300 to have a 30K service done by a professional? Most places I looked up charge 2 hours of labor.
Thx
Bluelogic
Old 05-17-2006, 12:27 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: 30K - Service for 2005 Ford Focus ZX4
you don't.
it's just a catch to get you in there and they can try to sucker you out of some money.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-17-2006, 01:05 PM
Well, I don't want to void my warrantee.
Thanks
Bluelogic
Old 05-17-2006, 01:15 PM
pre98zetec's Avatar
Thanks
Bluelogic
you won't void your warrenty by doing work yourself. atleast I've never heard of it happening. I use to do ton's of work on my car and took it in for a few warrenty fixes and nothing was said.
-Josh-
Old 05-17-2006, 01:35 PM
Ok, Thx for the advice. I'll replace the fuel filter anyway. Doesn't make a real difference in california, since the gas here has enough stuff in it to clean yout toliet.
Thx
Bluelogic
Old 05-19-2006, 04:00 PM
carlos80 carlos80 is offline
your warranty can be voided if for example your transmission fails and its said to have been caused by lack of maintance and you can't proof that you did it or that you used the correct kind of fluid then you're going to end up forking out some cash for that tranny and labor. remember that a drain and fill is not the same as an actual trans flush.
Old 05-19-2006, 10:23 PM
egc519mzl egc519mzl is offline
I always bring my car to a dealer if it is under warranty... Even for oil change... At least they have a record (I also keep my receipts) if something fails...
Old 08-28-2006, 12:33 AM
ppence418 ppence418 is offline
because it has to be done by a certified mechanic, not a back yard mechanic or it void ur warranty if something goes wrong, that's how they get ya, i know i have to have a radiator flush and a transmission flush done yet, that's about 250.
Old 08-28-2006, 12:34 AM
Old 09-01-2006, 08:22 PM
as long as its done and you have some sort of proof your warranty won't be voided, its doesn't have to be a certified mechanic. even at most dealerships the lube guys are not certified.
Old 01-11-2011, 11:17 PM
Transmission Guy Transmission Guy is offline
You can do the work yourself and buy any parts you want to to complete the work, just keep proof.
A law was passed to make this possible, it is called
THE MAGNUSON-MOSS WARRANTY ACT
Google it if you want validation
Jason Franciamore
www.transmissionkingatx.com
Old 01-11-2011, 11:53 PM
danielsatur danielsatur is offline
My Garage = Facebook for your Auto.
Keeps records, schedule maintenance, recalls ++++
or http://www.alldata.com
