Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 05-17-2006, 11:01 AM
ude_loose's Avatar
ude_loose ude_loose is offline
Send a message via Yahoo to ude_loose
91 626 Overheating
Just got a 1991 626 and i only drive it around for a little bit and it starts to over heat it has an automatic transmission I was wondering if this has happened to anyone and any idea what it could be...
Old 05-17-2006, 03:31 PM
hocbj23 hocbj23 is offline
Re: 91 626 Overheating
Lots of possibilities.If you have air, car has two electric fans, one that comes on when a/c comes on and one that comes on if car overheats.Work on thermostats. Let car warm up , turn a/c on and let car idle and see if both fans come on.Second possibilty is thermostat is stuck in the closed position. Cheap fix, thermo is right up front and easy to replace it and gasket.Third, radiator may need cleaning out and new fluid, also pretty easy fix. Hope this helps.BJ
Old 05-17-2006, 03:33 PM
Bump. Lots of other not so easy or cheap to fix problems like blown head gasket, etc., but check the easy things first. BJ
Old 06-05-2006, 11:21 AM
ude_loose's Avatar
well i got it all fixed came to be that my cooling system had a lot of air in it got it flushed ad put new antifreeze in their and i was good to go...
Old 06-05-2006, 12:34 PM
Great. Thanks for letting us know and glad u got ur ride working. BJ
