TPS Throtle Position Sensor
Can a bad TPS cause bad or late shifting of a transmission. I have a bad idle already. The car shakes and idle below 6000 rpms
Someone tell me please |
Re: TPS Throtle Position Sensor
You need to keep in mind that fuel injection is different from the old style carborators. Opening the throttle adjusts the air flow. The Air flow sensor sends a signal to the computer that tells it to inject more fuel. Fixing the idle usually requires cleaning the idle stabilizer out with carborator cleaner. The idle stabilizer is a bypass to the throttle that lets some air through as though the accelerator were slightly pressed. The knock sensor sends a single to the computer to tell it if the engine is running smoothly and the computer opens and shuts the idle stabilizer accordingly.
