Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-16-2006, 11:38 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
Red face fans wont work
when i bought my car the fans wouldnt work unless i hooked them up to a toggle switch. now im trying to figure out why it was ghetto rigged in the first place i replaced all the sensors on the radiator itself and checked all the wires and they all look fine and the fuse is fine.
does any one have any ideas on this one, i need to get these fixed so i can get a turbo timer.
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 05-17-2006, 12:01 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: fans wont work
Well, I don't know. But they don't turn on untill your coolant temp hits 210.
Old 05-17-2006, 02:34 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: fans wont work
there's a short somewhere. Replace all the wires, find where the toggle wires are coming from and find out where they should be.
now - 2000 civic
soon - 2002 is300
Old 05-17-2006, 07:33 AM
Re: fans wont work
there is only one wire that is there i hooked up the other to the negative and to the toggle i bought. the wire is coming from the fuse box under the hood attached to the fan fuse wire of course and then runs to the little ignition fuse box the connects to the positive on the battery and is tapped into the white wire there like its runing a constant power feed, cause if i didnt hook up the toggle switch and connected the wire it would just run and run
Old 05-17-2006, 09:18 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: fans wont work
Why don't you just have the fans on all the time? Or at least one of them, the ac fan only comes on with the ac.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
