Old 05-16-2006, 11:27 PM
DjEarth DjEarth is offline
Front end noises.
Hey guys..been a bit since I posted..have had no problems as of late.
But I got one now..hard to believe with our lovely Blazers
When I am driving..I get a weird noise when I go over bumps.
I have done the hood fix..so it's not that.
We replaced the linkage tonight..my mechanically inclined buddy thought it may be that..but still no fix.
It's not the shocks..those are newly replaced about two months ago.
It's definatly in the front..sounds like a creaking noise.
Wish I had a better explanation.
Any thoughts?
Much thanks in advance.
Old 05-16-2006, 11:35 PM
drdd's Avatar
drdd drdd is offline
Re: Front end noises.
I would start by lubing ALL the zirc grease fittings for your suspension (I think there are 11 or 12). Don't think this is too simple. Don't forget those upper ball joint grease fittings (you may need to remove the front tires to reach these).
could be various bushings, but I'd start with the grease.
Any thoughts?
Old 05-16-2006, 11:43 PM
Everything is getting lubed up on Thursday..and has been on a continual basis, but the noise is still there.
Old 05-16-2006, 11:55 PM
nickledimed's Avatar
nickledimed nickledimed is offline
Send a message via Yahoo to nickledimed
Just a shot in the dark, but I was getting a funky squeek in the rear, so I shot my springs with penetration oil and it stoped....lol....shoot just were the springs touch something....yea I know the springs are dif in the rear...but...itsa shot in the dark...
08 Equinox LT
Old 05-17-2006, 12:25 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Creaking noise = usually dry ball joints.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-17-2006, 08:50 AM
joeuser742 joeuser742 is offline
I second that.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 05-17-2006, 11:29 AM
Alright guys..it's going in for service tomorrow..I'll get them lubed up, see if that makes the difference.
Old 05-17-2006, 12:44 PM
Paperboy1996 Paperboy1996 is offline
I would check the front stabalizer bushing or sway bar bushings - this fixed mine.
Old 05-17-2006, 02:42 PM
BlazerLT's Avatar
AF -Advisor
Do it yourself, they NEVER get the 10-11 fittings.
Also, as I did today, you always pump in 4-5 pumps of grease while there is no weight on the wheel in order to get the grease properly into the ball joint.
Jack up the wheel just so the weight is off of it, lube the upper and lower balljoints and drop it
Then do the other side.
Then the inner and outer tie rods
Then the idler and pitman arm
I just lubed my front end, what a difference, smooth as silk.
Old 05-17-2006, 08:04 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
I have the creaking as well, ball joints it is!
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 05-18-2006, 04:05 PM
Well we just lubed everything on that list like you said LT, and the noise if gone. Much thanks for that easy fix..thas what I get for leaving it to the shop to say they did it I guess.
Old 05-18-2006, 05:43 PM
BlazerLT's Avatar
AF -Advisor
Yip, NEVER trust the shop.
Old 05-22-2006, 06:26 PM
I wish someone would lube my ball joints..........as always, gotta do it myself...sheeesh
08 Equinox LT
Old 05-22-2006, 07:15 PM
TDQ TDQ is offline
Mine did that and needed ball joints...What a pain in the a$$ job to do on my 2000.
Old 05-22-2006, 09:44 PM
BlazerLT's Avatar
AF -Advisor
Remember to lube the balljoints with no weight on the tires. Jack the side you are greasing up so you can fill the joint properly or you won't be getting much in.
