Old 05-16-2006, 09:49 PM
Mac2002 Mac2002 is offline
99 duratec long crank when cold
1999 Duratec, 109,000 miles. Used to start immediately when the key was turned. Suddenly, one day after using Techroline fuel injection cleaner, it takes about 2 full seconds of cranking when cold (45-60 deg.) to start. Starts immediately when hot. Runs great cold or hot. Has all the power it ever had. The techroline may be a red herring; don't know. Haven't done anything since but change the fuel filter, then only because it was scheduled. The check engine light has never come on. Thanx
Old 05-23-2006, 11:08 PM
Re: 99 duratec long crank when cold
Bump
Old 05-24-2006, 06:35 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Install a fuel pressure gauge before you start vehicle and see how long it takes for pressures to reach around 40psi. It should jump immediately. You can also try turning the key to the "on" position 2 or 3 times before you crank it over. If it starts easily then, it is indicitave of a weak fuel pump. If it makes no difference, could possibly be coolant temp sensor or other sensors on the engine to control cold start. Without having my hands on the car and scan tool hooked up, it is just a guess.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-06-2006, 01:30 PM
Thanx, Way2old. I'll give that a try.
