Old 05-16-2006, 05:47 PM
jsejse jsejse is offline
Leaving on a Road Trip
Hi
I have a 1998 dodge grand caravan. I'm leaving in the a.m. and discovered my power suppy (cig lighter) isn't working. Can't use the GPS without it. Where would the fuse be located for this.
Thank you
Old 05-19-2006, 03:05 PM
nixonrules nixonrules is offline
Re: Leaving on a Road Trip
I had the same problem with mine. The fuse is in the fusebox under the hood (in the engine compartment) right next to the battery. The underside of the cover has a map of what's where. Might as well make sure you have a couple spares while you are in there. Good luck!
