Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 05-16-2006, 06:04 PM
americanbulldog americanbulldog is offline
? about 1992 eagle talon factory alarm
hey
my friend brought a 1992 eagle talon with a factory alarm in it.andthe person he got it off of dident have the alarm clicker thing to turn n and off.and when he cant start it up bcouse the alarm wont get off.and when he connects the vbattery cable the horn wont stop beebin.so can any one tell me how to take the alarm outor disconect it.so he can start it up.
thanks or even a wire diagram
Old 05-16-2006, 06:17 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: ? about 1992 eagle talon factory alarm
He can turn off the alarm by putting the key in any door on the car and unlocking it. If he can't do that then just pop off the door panel and take the two wires that go the the lock and put the two wires together and it should turn off the alarm. You don't need to keep them together just put them together and start the car. I hold no responsibility for any damages you do but I know that this works.
Old 05-19-2006, 07:29 AM
ned032002's Avatar
Well....did it work?
Old 05-19-2006, 03:41 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
It's easier than that.
Inside the car on the passangers side infront of the door is a panel below the dash. pop that off and there is a black box in there. unplug that and wala no more alarm.
1991 GSX 2.3 Stroker
Old 05-20-2006, 09:17 AM
ned032002's Avatar
That turns it off for good? That's probably the best way to do it because without the key ring alarm remote he can't use it anyways so why have it.
Old 05-20-2006, 12:05 PM
defiancy's Avatar
Yep that disables the whole thing. And if you ever find a substitue ring you can just plug it back in.
Old 05-20-2006, 08:52 PM
hello,
dident try it yet.i might buy the car off him for $1000 and then fix it for myself.he had it for a couple months and it just sits thereand its a tsi.turbo is new.and many other thuings are new. the only things he needs.is to stop the alarm.wich he drove it to his ouse and it drove perfect then he turned it poofff and on again,and then it wouldnt stop beepin and wouldent let him start it.so when he has a charge in the battery and connects the cable it just beeps and bees untill the battery dies.so is i get it ill just disconnect the whole thing like u guys said,from the passenger side.,so will that def make it better so he can start it.
but the only thing he needss is a rear rim.and the valve gasket.everything else is in waorkin condition.
so do you guys think its worh gettin for $1000-1500 and then fixing it up.its a tsi and turbo is new.he has some steel braided lines in teh engine dn what they are but its not bad.from looks.
and dont the 92 talons have a timing belt problem.and what are also some known problems they have.
thanks
Old 05-21-2006, 02:03 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
yeah it's worth 1-2k maybe more depending if it has some mods. The timing belt should be replaced every 60k miles. If not it could have problems but not any more than other cars. I would buy that for sure, if you don't let me know so i can add it to my family of dsm's.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-21-2006, 03:18 AM
hey ez1286
is it expensive to get the timing belt done.like how much does the laber cost.becouse if i get it for like 1k then i have about a grand to do shit to it.i have more just want to spend that much,
thanks let me know.and what is the best timing belt.is the greddy timing belt good.its supposed to resiste heat more and be stronger but let me know.becouse ill buy it tomorrow.
thanks
Old 05-21-2006, 04:29 AM
ez1286's Avatar
Well i think it will be pretty expensive at a shop. I'd say book time is more than 5 hours, but i'm not sure on that. You could go for a greddy belt but i really don't think it's necessary, an oem belt should be fine. You should also replace all of the components that go with the timing belt (idler pulley, tensioner pulley, and hydralic tensioner) You can buy it as a kit here http://www.slowboyracing.com/shop.php?sid=&cat=1054 (near the bottom of the page) If you don't have much experience working on cars you probably want it done at a shop. BTW you should also remove the balance shafts as long as you have that side of the engine apart.
Old 05-30-2006, 09:32 PM
some more info he has a new turbo in it,a newer crate engine with 40k miles .and he just needs some thing in the shifting its like a $2 part but labor he said.and needs a rear tire and rim is bent.and then the factory alarm he dont have the clicker to turn it off and messed wires up so when he connects the battery it just blinks and the horn goes crazy untill it dies.so with those problems .i am gunna buy it tomorrow if every one thinks its worth $1500 i offered and he accepted becouse he is going ever seas.
and if the alarm is going crazy and i did what u guys said by going under the right side in the car and disconnecting it would it run.with the alarm disconnected.
thanks
Old 05-31-2006, 01:01 AM
defiancy's Avatar
thanks
yep it'll run with the alarm disconnected. My car alarm is disconnected like that and runs fine
Old 06-02-2006, 07:23 PM
ned032002's Avatar
The engine alone is worth what your paying, post some pics as soon as you can.
