| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
#1 | |
Banned
As I stated in my last thread I replaced everything but the kitchen sink my idle is still not right.I did the idle re-learn but did not help.Now the idle bounces up and down between 950 and 500.As a refresher I replaced control module,IAC,EGR, and TPS.Also I put new plug wires on,car is not throwing any codes so now I'M stuck.Any help or suggestions would be great,I want to try and avoid taking it to a garage. Thanks in advance.
Paul Sorry it's a 93' 3.1 Last edited by caper63; 05-17-2006 at 07:10 PM. |
#2 | |
A990 racer
![]() Join Date: Mar 2002
Re: Confused
You have eliminated any possible vacuum leaks, poorly seated or bad pcv system? Throttle body vacuum leaks?
#3 | |
stupidity should hurt
![]() Join Date: Aug 2004
Re: Confused
year and engine size please
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
#4 | ||
Banned
Re: Confused
#5 | |
Banned
Re: Confused
As far as I can tell I have no vacum leaks,but am starting to think there may be a leak where the plenum meets the intake manifold.Is there any way I can test this before I pull the darn thing apart.As I forgot to mention in my first thread it is a 93 - 3.1.Also I can not find the PCV valve at the back of the plenum,that's where it was on my last lumina.
#6 | |
Re: Confused
Spray carb cleaner or wd-40 around the seams between the upper plenum and the lower intake with the engine running. If the idle changes, you have a vacuum leak. What is the 8th digit of your car's vin? If its a W, the pcv valve should be mounted in the rear valve cover, about in the center. If it's a T, it should be in the intake, tucked under the edge of the upper plenum.
