Old 05-16-2006, 04:35 PM
Cbierniat's Avatar
Cbierniat Cbierniat is offline
bolt pattern
20x8.5 SIZE RIMS WITH A 5-112
BOLT PATTERN
would those fit on a 99? they were off an intrigue
Old 05-16-2006, 05:31 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: bolt pattern
Our bolt pattern = 115mm X 5. Are you sure that is the right bolt pattern from the Olds Intrigue? It is a GM "W" body car and last time I checked shares the same bolt pattern with a Grand Prix or Regal.
Timeslip 08/12/06
AF Community Guidelines
Old 05-16-2006, 06:26 PM
Cbierniat's Avatar
Re: bolt pattern
its off a 2000 intrigue...its an add in a the paper i was jwin...42mm...maybe the guys is mistaken...put itt his way..if theyre off an intrigue would they fit??
Old 05-16-2006, 06:35 PM
BNaylor's Avatar
Re: bolt pattern
The Intrigue and Grand Prix use the same hub by part number and that includes the pattern of the studs. Best thing to do is try it out if possible. Good luck!
Timeslip 08/12/06
Old 05-16-2006, 08:00 PM
Cbierniat's Avatar
Re: bolt pattern
thnaks
Old 05-16-2006, 10:03 PM
Liljay2003 Liljay2003 is offline
Re: bolt pattern
What does the bolt pattern actually mean< so i cant just take 5 lugs rim off of another car that has 5 lugs< and i wont work> I was going to buy some 18s off of a eclipse and our bolt pattern is different< but the dounut on the eclipse fits my car, I think the bolt pattern on the eclipse is 14.2mm x 5 will that work on my Grand Prix GT. Note the rims are chorme not fatcory eclipse rims.
Old 05-17-2006, 07:14 AM
BNaylor's Avatar
Re: bolt pattern
Normally the bolt pattern on a wheel should match or it won't fit on the wheel studs located on the hub. We have 5 studs/bolts and they are spaced out at 115mm. The other problem you may run into even if they did fit bolt pattern wise is the offset. Without sufficient wheel offset the inner parts of the wheel would probably rub against the brake caliper or mounting bracket.
Timeslip 08/12/06
Old 05-17-2006, 04:11 PM
Re: bolt pattern
So with the eclipse rims (custom rims) wont fit with the bolt patterns are like a half a mm off. Dont most of the newer rims are universal< So maybe i can check and see.
