Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 05-16-2006, 03:49 PM
Psywar Psywar is offline
Send a message via ICQ to Psywar Send a message via AIM to Psywar
Welder question
Second post..
I have had a few questions built up for a while..
I have an Arc Welder..
Just a standerd 115VAC
Can I weld Stainless Steel, and Aluminium with this?
Do I need a special flux?
I notice alot of people use a MIG to weld SS or Alum.
I dident know If it was possible or not to do with an ARC..
Thanks
-Chuck
Old 05-22-2006, 09:36 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Welder question
You cant weld Aluminum with a stick welder, but you can weld Steel and Stainless. For stainless use E316-16 Rod.
MIG welding stainless and aluminum give fair results. I'd much prefer to TIG weld stainless. Welding aluminum with MIG is a waste of time. Either o/a weld or TIG weld depending on the shaping you plan to do.
-Mike
Old 05-23-2006, 11:02 AM
Re: Welder question
Dont know if I could ever afford a TIG in this lifetime..
Hrmm..
I have an Arc welder..
I am currently saving for a nice MIG
What I am going to be using it for is mostly car things.
I want to weld up a 2.5" S.Steel Exaust for the car.
and When I do my Intercooler it will all be Alum. Pipeing and I wanted to weld all that up as well..
I guess we will see what happens
Old 05-23-2006, 10:18 PM
mike@af's Avatar
Re: Welder question
Hrmm..
Go TIG. You will need AC TIG to do aluminum. So look for an AC/DC Setup. Miller sells the EconoTIG at an affordable price. Its the lowest prices AC/DC TIG Welder. I've used it and I love it, its a great welder.
The problem with MIG is you always have to change the type of sheilding gas when welding different metals. Mild steel you can use C25 but with stainless you need a Trimix. Welding aluminum with MIG is just a mess.
Heres the EconoTIG: http://store.cyberweld.com/milec230vol.html
Check on eBay too.
-Mike
Old 05-24-2006, 03:39 PM
Re: Welder question
wow.. 1400... I guess i can hold off for a few more months to get something really good..
Thanks for the Info and for the link..
-Chuck
