Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-16-2006, 02:52 PM
Ridleyj329 Ridleyj329 is offline
idle speeds
just out of curiousity, what sthe normal idle speed on a 94 sl1. mine is give or take 1000rpm when i sit still and im in st louis so the weather is always bouncin around if that makes any difference. would it be bad if the idle was set too low? jw. im in the process of gettin her up to par so if just let me now if theres anything i can do to fix this if i need to. again. dont think its bad but just curious. thanx
Old 05-16-2006, 05:12 PM
koolkash_45 koolkash_45 is offline
Re: idle speeds
mines around 850 so not but 1000 is a little high
Old 05-17-2006, 04:26 AM
Re: idle speeds
i just check it out again and was maybe about 600. hows that?
Old 05-17-2006, 11:47 AM
XxPurpleHazexX XxPurpleHazexX is offline
Re: idle speeds
Idle RPM speed will varry depending on how warm the engine is. When the engine is first started it will idle at a higher RPM to warm the engine up faster.
Old 05-17-2006, 01:58 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: idle speeds
idle speed depending on engine and options is about 650-850. it is not adjustible and the tach is not a perfict reading so you should be ok.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
