Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 05-16-2006, 12:19 PM
truckpoor's Avatar
truckpoor truckpoor is offline
irregular motor revving
Just changed the alternator out of my wife's 2001 PT. Started it back up and now the engine is revving up and down. Only going about 200-300 rpm's, but it cycling about 2-3 times per second. Going to check the hose between the air cleaner and throttle body today, but anyone have any other clues? Thanks in advance.
Old 05-16-2006, 10:27 PM
santacruzr santacruzr is offline
Re: irregular motor revving
Maybe you could try resetting the PCM by disconnecting the battery for 10 minutes? It sounds like an engine management issue?
Old 05-17-2006, 09:33 AM
truckpoor's Avatar
Once it turned daylight again, the problem became pretty apparent. I had knocked a vacuum hose off while reaching down the back of the engine compartment sometime during the alternator swap. Runs fine again.
