Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 05-16-2006, 11:25 AM
jcampbell23 jcampbell23 is offline
89 sierra engine pinging
my 89 sierra will start to make a pinging or chatter type noise when i mildly accelerate. someone told me it might be the valves sticking .the oil psi is always on or near to 60psi , what could it be and how can i fix it . thanks
Old 05-16-2006, 01:37 PM
maxwedge maxwedge is offline
A990 racer
Re: 89 sierra engine pinging
If the timing is good check for proper egr operation.
Old 05-17-2006, 12:41 PM
i checked the egr valve and it works good , do you think if i put some marvil mystery oil in, it will help . or anything else you know of. thanks
Old 05-17-2006, 01:13 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
As maxwedge said, have you checked the timing? If the timing is to far advanced then it will ping. Also if you are running a performance chip and it requires a higher octane gas and you are running a lower octane it will also cause pinging. If both of these are ok and the pinging is still there you may want to test your knock sensor to see if it is working.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
