Old 05-15-2006, 10:26 PM
deltableh deltableh is offline
Send a message via ICQ to deltableh Send a message via AIM to deltableh Send a message via MSN to deltableh Send a message via Yahoo to deltableh Send a message via Skype™ to deltableh
Decal edges on complex corners... HELP!
I'm having trouble getting the edges of some of the decals on the CLK I'm doing to stick, because they wrap around complex corners. This is especially true on the wheel-wells and the hood, around the headlamps and grille.
Any ideas on how to get them to stick?
Old 05-16-2006, 01:25 AM
Captain Mark's Avatar
Captain Mark Captain Mark is offline
Re: Decal edges on complex corners... HELP!
Have you tried using some MicroSol on them at all?
If not it's probably worth getting a bottle, if I understand your problem correctly.
Old 05-16-2006, 10:33 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
+1 for microsol.
or, you can actually use a warm damp towel and use it to press on the decal, making it conform to the surface, like in http://tamiya.com/english/howto/car1/tip5.htm
olly olly oxen free
Old 05-16-2006, 11:11 AM
I have MicroSet, and I'm literally painting the decals in the stuff.
Old 05-16-2006, 11:22 AM
935k3's Avatar
935k3 935k3 is offline
Try a hot damp cloth pressed firmly over decal. Also if its lifting try some white glue under the decal. The cloth works instantly and leaves no wrinkles.
Old 05-16-2006, 01:46 PM
winstona's Avatar
winstona winstona is offline
Microsol is much much stronger than Microset. Buy a bottle and you will notice the difference. No matter how much microset you put on, the decal will not conform.
You can also try Solvaset. This is much stronger than Microsol from my reading in this forum. I personally have not used it.
Microsol will almost "melt" the decal and make it conform to any shape. The decal will stick very well afterwards.
Winston
Old 05-16-2006, 03:49 PM
mickbench's Avatar
mickbench mickbench is offline
You could always use vinegar diluted in water.. That’s basically what mico sol is. In fact the two products are pretty much the same, just that one is stronger then the other. Microscale seem to have marketed the two pretty well, saying you need both, whereas you don’t actually. Some decals will melt around the edges with just micro set. Whereas some need a little more, Tamiya decals are well known for being pancakes.. Whereas I’ve just used some Crazy modeler decals, and these registered to the surface superbly, and just needed pressing into place with a damp finger. I still applied micro sol AFTER they were in place, as sol does melt the decal, and is great if you are to apply a clear coat afterwards.
Hot towel works quicker and even faster with a hairdryer, but you need to use this on low heat, or else it can warp the plastic.
Old 05-16-2006, 03:51 PM
mickbench's Avatar
Oh, sorry for the thread hijack, but Captain Mark – Did you ever finish that BAR?
Old 05-16-2006, 05:33 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I use Daco's products which are great
http://ultra.glo.be/daco/Ksetting.html
I should be stocking this stuff in the near future
Steve a.k.a. Hiroboy
Old 05-16-2006, 05:41 PM
mickbench's Avatar
"Once you've used DACO's Decalsetting, you'll never use Microscales Sol & Set ever again ..."
From their website. Thats a pretty bold claim, it doesn't come anymore "this is better" then a statement such as this..!! That good eh...!!? Must admit, first I've heard of this decal setting solution. Learn something new everyday. Everyday's school day.
Old 05-19-2006, 03:40 PM
drifter_fan's Avatar
drifter_fan drifter_fan is offline
solvaset works great. ive personally never used microsol, but ive heard its good.
you need to be careful with solvaset and small decals, as if you use too much, it may actually disolve the decal.
-Julian
