Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-15-2006, 09:16 PM
Tony022 Tony022 is offline
plugs/wires/fuel filter
95 Aurora and have a miss problem, getting worse and starting to idle rough.
From all the posts it sounds like I should start with plugs and wires. What's the P/N for the NKG plugs? Whats the price difference in AC Delco and NKG.
Fuel Filter...Where is it?
Should I use never seize on the plugs? and a silicon jell on the plug to wire connection?
Tks..
Old 05-16-2006, 09:51 AM
tjm's Avatar
tjm tjm is offline
Re: plugs/wires/fuel filter
Tks..
Yup - get the basics done first -
Only use OEM - AC Delco plugs and ABSOLUTLY be sure to use never-seize
Wires are up to you - lots of positions on wires but IMO the LIFETIME waranty wires from AutoZone are fine. they replace them for free and for no reason too.
Fuel filter is located under the car below the driver's side rear passenger. Use never-sieze on the fitting here too.
Be sure to complete the tune-up with a new PCV valve and air filter.
One final thing you should do is to clean the throttle body. Check this link At the Aurora Club of North America for the procedure. http://aurorah.proboards47.com/index...ead=1121714117
'97 Majestic Teal Metalic, 233,000 miles of smiles
Member of the AURORA CLUB OF NORTH AMERICA
Old 05-17-2006, 01:30 AM
androsvalentino androsvalentino is offline
denso iridium plugs. (densoproducts.com) vitek wires. (vitekperformance.com) jegs coils. (jegs.com) eco . (ecofuelsystems.com)
already added plugs. waiting on rest. will post results. also intake.
Old 05-17-2006, 05:30 PM
Replaced the plugs and wires with AC DELCO. What a difference. All the bucking, hesitation went away. Runs great. Who ever designed the mounting of the coil pack, wow. Well it's back on but with the two front bolts only.
Just for grins I called the Olds dealer and asked how much the job would be and the quote was $525.00. WOW. He did say it was labor intensive. Parts cost me $165.00---that leaves $360.00 labor Gee I didn't know what I was doing and it took me 3 hrs. And that was doing one wire at a time. I guess I'm in the wrong business..lol.
