Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-15-2006, 09:04 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
Fuel pressure?
what is the stock fuel pressure on a b18b1?
Old 05-15-2006, 09:28 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Fuel pressure?
40-47 psi.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 05-16-2006, 03:32 PM
Re: Fuel pressure?
thanx, have a motor but had no fuel rail on it an i had an adjustable fuel press. reg. with aem fuel rail layin around so i figured i would use that jus needed to know what press. to set it at.
Old 08-14-2006, 08:48 PM
Sadowski Sadowski is offline
Re: Fuel pressure?
That 40-47 psi on the stock set up is when the vacuum hose is disconnected from the fuel regulator. When the vacuum hose is attached on the regulator fuel pressure should be between 31-36 psi. You probably shouldn't have a problem though.
