Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-15-2006, 08:49 PM
bluesteelrock bluesteelrock is offline
question
d17, is it possible to naturally aspirate that car into 200 hp and equal torque, with good air flow maybe cam and ecu, if not that then what just to be on the d17 side ( which came to the car )
Old 05-15-2006, 09:58 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Re: question
Not too much available for HP increases on the D17's yet. I don't know what the stock WHP is but I know the torque isn't all that great. From what I know about available upgrades you may be looking at some custom work to get both up to that.
AF COMMUNITY GUIDELINES
Old 06-07-2006, 07:02 PM
civic95dohc civic95dohc is offline
Re: question
D17A1
  • Found in:
    • 2001-2005 Honda Civic DX/LX
      • Displacement : 1668 cm3
      • Bore and Stroke : 75 mm X 94.4 mm
      • Compression : 9.5:1
      • Power : 115 hp @ 6100 rpm & 110 ft·lbf @ 4500 rpm
      • Valvetrain : SOHC
      • Fuel Control : OBD-2
a little reseach, and thinking, and i say its not impossiable, but i wouldnt waste your time and money, do a B series swap and you would be 3/4 the way there with a stock motor
always check your oil pressure
