Old 05-15-2006, 08:16 PM
umina umina is offline
windows creaking
Hey there, I know there is a TSB out for this, but don't know what the fix is? When I power up the windows, they get to the top and then creeeek back down. This happens on 3 of the 4 windows. Drivers window makes a creek all the way up, sounds like something is dragging, but seals are soft and look OK. I'm also getting excessive wind noise from all 4 windows. How hard is it to "upgrade" to the newer door seals used in the newer models (mine is an '01, I drove an '05 and MUCH quieter). Thanks in advance!
Old 05-16-2006, 05:25 AM
Millermagic Millermagic is offline
Re: windows creaking
I'm not really sure what to say other than take the door apart and look inside to see if everything is tight.
Old 05-16-2006, 11:29 AM
Willyum Willyum is offline
My '02 windows creak seating at the top of their run. The dealer should have info on a lube they have for them but if the dealer does it they charge an amount close to equal the blue book value.
Old 05-17-2006, 08:38 PM
Anyone else know about this "lube" for the window seals? I'm game to try anything at this point, its driving me bonkers. I really try to avoid dealers at all costs where possible, I just don't trust their shop guys.
Old 05-18-2006, 12:53 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Hmm, I don't know of any lube. I suspect the lube gets installed on the window regulator assembly somewhere. Seems to me a proper fix may be to install teflon washers on the mounting bolts for the regulator assembly. If you are referring to the same creak that I hear when my windows reach the top, the noise appears to be coming from inside the door. I've always suspected the creak is due to the regulator shifting/twisting when the window is stopped but the motor is still applying torque.
-Rod
Old 05-18-2006, 10:40 PM
There was an article or reference to a tech bulletin about the window creak in Popular Mechanics some months ago. Sorry I don't have more info about it or exactly what issue. I took it to the Ford dealer I'm familiar with and they said they could lube them for me if I wanted.
