Old 05-15-2006, 08:07 PM
planet_keeper's Avatar
planet_keeper planet_keeper is offline
Hesitation issue
Sometimes my car accelerates a little jerky, especially when I first get in it and after a couple minutes of driving goes away. I usually let it warm up for 20 or 30 seconds before I drive it. Is this pretty common or could it have something to do with the oil change that I'm a couple miles overdue for?
'93 black vr4, HKS boost controller and gauge, gutted pre-cats, 3sx downpipe, intake, 18" zenetti rims, tein-s springs
Old 05-15-2006, 08:13 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: Hesitation issue
I would highly doubt it has anything to do with the oil being dirty if your a few miles over due. Have you checked the plugs and wires. Bad spark can cause those symptoms.
Old 05-15-2006, 08:25 PM
The guy I bought it from had the plugs and wires changed last september so it shouldnt be that unless the plugs are just terrible quality. He said that they were platinum plugs from some brand I can't remember.
Old 05-15-2006, 08:47 PM
VR43000GT's Avatar
What about the ignition module (basically the newer version of a distributor)?
Old 05-15-2006, 09:08 PM
im not sure if he got that changed, ill have to ask.
Old 05-15-2006, 09:10 PM
VR43000GT's Avatar
You can get it tested at most auto stores such as Napa, O'Reilly, etc. for free. However, if it is going bad they are not cheap to replace.
Old 05-15-2006, 10:48 PM
mehrshadvr4 mehrshadvr4 is offline
if it's boshe it's suck.i had a problrm with them,and when i changed those to NKG it fixd everything.
Old 05-15-2006, 10:50 PM
Igovert500's Avatar
blue + red light magnet
Find out what type of plugs he put in. Some brands don't work to well with our cars.
Generally an on/off hesitation is spark related. With the mods you have, it may simply be that you are getting spark blowout under boost.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-18-2006, 06:57 PM
yeah looks like its running bosch's under the hood. ill go out tomarrow and get the ngk plugs while I get oil for it too.
Old 05-18-2006, 09:50 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
maybe he gapped the plugs goofy or something???
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 05-19-2006, 03:38 AM
according to him he had a shop do it while they were rebuilding the tranny, replacing the clutch/wires/stuff/etc. so unless he told them to i doubt it. i'm gonna be busy over the weekend but on sunday i should have some time to put hte plugs in and change the oil and stuff and i'll let you guys know what turns out. if that doesnt fix it ill take it to get the ignition module tested.
its kindof a weird problem though. it seems the warmer the car is from the sun or engine, the mroe the problem goes away. over here in seattle we been gettin 80+ degrees every day now and I dont notice the problem unless I drive it in the morning (which is usually when I drive the '85 honda beater).
Old 05-19-2006, 01:54 PM
Igovert500's Avatar
Could it be moisture related, rather than temp related? ie, morning dew
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-19-2006, 03:41 PM
i dont think its moisture. its garage kept and its pretty dry in there
Old 05-20-2006, 01:54 AM
From what i've read on the forums here i'm thinking that im going to make a switch from the castrol synthetic blend 10w30 that the previous owner used to the castrol syntec 5w50. anyone have any opinions on it or other oils i should consider?
If driving conditions matter, I usually use the car for short-ish trips with spurts of spirited driving.
Old 05-20-2006, 10:09 AM
Igovert500's Avatar
Read the FAQ, there is an oil thread in there.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
