Old 05-15-2006, 07:16 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
engine stalling after rebuild
i have a 92 tsi awd, i just replaced everything in the upper part of the motor including a brand new 6 bolt head, hks head gasket, arp everything the whole nine yards. now i made sure everything lined up timing wise and all that replaced all the timing components and stuff but it stalls after idling for like 2 seconds
any ideas
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 05-15-2006, 07:51 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: engine stalling after rebuild
Did you check the compression, spark and fuel?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-15-2006, 09:27 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
is your cam sensor off 180 degrees?
Old 05-15-2006, 10:39 PM
yea compression was 195 in all cylinders and the spark and fuel were all great, so i will check my cam angle sensor tommorrow when i get off work i didnt get a chance to do to much with it, it poured all day.
Old 05-15-2006, 11:01 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Originally Posted by wanaplay134
it poured all day.
That's why we have what one would call a "building", it keeps you dry.
95 Talon TSI AWD
97 Eclipse GST
Old 05-15-2006, 11:12 PM
EDMUND65's Avatar
also may want to put a noid light ont he injectors to see if they are firing when you crank it... if that is weird its eithe ryour ecu or mpi or mfi relay...
Old 05-15-2006, 11:13 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Well not everyone has a fucking "building" ok?
Ignition timing thats off will cause a shitty/no idle and stalling wont it?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-16-2006, 05:01 PM
no whats shitty is i just bought this house and when i did the garage needed repaired and the neighbors compalined and before i even moved in the county tore it down and left me with nothing.
but its fixed the line to the pcv valve was off and i turned the cam angle sensor 180 and it fired up and with barely any adjustments idles perfect at like 750 thanks guys for the help
