Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-15-2006, 06:48 PM
cbfloyd cbfloyd is offline
97 SC2 Bad transmission
Hi,
I have a 97 SC2 with an automatic transmission. The car has 195000 miles on it. The transmission gave it up. I do not want to spend alot of money on a transmission to put beside an engine with that many miles on it. So what I would like to do is to find a lower milage engine/transmission combo and replace them both. I found a 94 SC2. I know that things changed in the year models but does anyone know if it would work since I am changing out both the engine and transmission? Any input would be greatly appreciated.
Thanks
Old 05-17-2006, 01:17 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: 97 SC2 Bad transmission
the engine would work if you swaped the 97 manifolds and sensors on. i beleave the transmission will not work due to a difference in gear raitos and electronics, you may want to call a dealership and as a tech to confirm, or try saturnfans.com
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 05-17-2006, 11:59 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
gear ratios were the same with the mp7 trans throughout that time. the egr on the 94 is a vacuum operated one while your 97 has a electronic egr. the 94 head also has an extra coolant sensor, which isnt a big deal at all it can be left in the head and nothing plugged into it. the biggest problem is the egr. im not certain if the egr mount is the same and can be swapped or not because i havent looked into the vacuum operated egr.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 05-19-2006, 12:37 AM
as yes i forgot about the EGR, 97 has a electric EGR, 94 had ether a vacuum EGR(federal emissions) or a Electic EGR(cali emissions). the mounting is not the same. the 94 head is designed for a vacuum EGR, with a adaptior plate used for the electronic EGR. with some luck, your donor car may already have the adapter plate. because they are a little costly and hard to come by(i've never seen one for sale or in a junk yard) the dealership may be your only option for this part
