Old 05-15-2006, 06:39 PM
jtfrog's Avatar
jtfrog jtfrog is offline
Angry 02 bad again
I replaced the 02 4 months ago and now code 43 says it is bad again Whats up please help. This is for a mid 90's Accord
Old 05-16-2006, 03:46 PM
somick's Avatar
somick somick is offline
Re: 02 bad again
I am not sure but I believe Accord has two O2 sensors.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 05-17-2006, 01:20 AM
jtfrog's Avatar
Re: 02 bad again
THay due and I only changed the one,shouls i now change the other,pricy
Old 05-17-2006, 07:53 AM
Igovert500's Avatar
blue + red light magnet
Re: 02 bad again
code 43 is a fuel supply system error code. Why on earth did you replace the 02 sensor in the first place?
From what I found, code 43 could be: Fuel supply system circuit OR fuel supply system...not sure which. I'd start checking out:
I'd replace the fuel filter if it has over 60k on it.
Then I'd
1. Check the fuel pressure
2. Check the fuel pressure regulator and all accompanying vaccum hoses for air leaks.
3. Fuel pump ( can you hear any noise from the fuel pump) it might not be getting enough voltage at low rpms. Hotwiring it would solve that specific issue.
3. Vacuum leaks
Also there is an an "IMPORTANT" thread titled 'service manuals' at the top of the accord forum. Check in there, and you can download your appropriate service manual, and see what instructions it gives you for diagnosing this problem.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-17-2006, 11:38 AM
jtfrog's Avatar
Re: 02 bad again
thanks for help everyone
Old 05-18-2006, 07:51 PM
StealthSonic StealthSonic is offline
Re: 02 bad again
Ok I did the batt reset thinggy and it didn't work. Engine checklight came back after 3mins or so.
I switch to another O2 sensor (used working) and did the batt reset and this time engine checklight comes on instantly.
Im thinking of buying a new O2 sensor again... But I doubt that will fix the problem. I'll try to bring to Honda shop this week. Will let you know.
I found a guy who had this problem from another forum. He said that you have to get the O2 sensor that is made for ULEV V-Tec. I'm not sure if this is true, because I got the O2 sensors from the dealer... I don't think they have ULEV version at all. But u could try. I'll run down to the dealer and see what they have to say.
http://importfan_accord.homestead.com/files/New_Page_Accord.jpg
Old 05-18-2006, 07:53 PM
Re: 02 bad again
SORRY!! Wrong forum... Disreguard what I said. This is for the misc. error code 1167 (primary Oxygen sensor failure.)
Old 05-24-2006, 03:45 AM
jtfrog's Avatar
Re: 02 bad again
Then I'd
3. Vacuum leaks
I talked to the person and they say they are also having a brake problem. When at a stop sign the brakes creep to the floor but when at speed they work fine. Could this be a vacum leak or brake booster?
Old 06-08-2006, 02:15 AM
redly1 redly1 is offline
Re: 02 bad again
hahaha..mid 90's accord.
that made me laugh
wouldve been easier/more helpful to just state the year
