Old 05-15-2006, 04:37 PM
8_men 8_men is offline
Unhappy need help
hi there everybody......im new here to the forum.......well i have a 91 3000gt vr4 with a k&n air filter, rfl blow off valve, and y pipe. the reason im posting is because my car laggs at 4k rpm on every gear and then sometimes it back fires. i am not really sure what might cause the problem so i need help. any suggestions of what might be causing this problem?
Old 05-15-2006, 05:39 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: need help
Your airflow sensor may be defective or you may have a leak somewhere in your intake causing your car to run rich would be my guess.
Old 05-15-2006, 06:02 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: need help
I bet your RFL is leaking. Why do you have one if you dont have any other mods?
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 05-15-2006, 07:05 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: need help
why not? b/c its "Really Freakin Loud"!
would spark blowout cause a lag/hesitation?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-15-2006, 07:24 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
Re: need help
^I'd think so, but I think tal skinny's right in saying that it may be leaking... I mean open loop's usually cause the car to run rich between shifts and most require tuning in order for the BOV to actually function w/o problems...
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 05-15-2006, 10:48 PM
Igovert500's Avatar
blue + red light magnet
Re: need help
Miles and maintaince?
Boost leak, whether from the BOV or somewhere else could be the issue. The BOV would cause rich conditions and backfiring possibly even stalling issues.
How are your rpms at warm idle? Do they fluctuate or stay steady?
When you say it lags at upper rpms, do you mean like an on/off hesitation, or it simply continuously lags?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-16-2006, 01:26 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: need help
I vote crappy BOV. The Turbo XS RFL BOV has been known to have problems every once in a while. I'd suggest getting an HKS SSQ BOV.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 05-16-2006, 07:06 AM
Re: need help
Or just put your stock one back on and see if the problems go away.
