Old 05-15-2006, 02:21 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Coolant Light/Leak
Hey guys, i know its been brough up before but i cudnt find an answer. Light came on while driving to work, figured electrical prob, turned off and on, still on. Then when i got home that night it was still on, i looked and the tank was low, i put in over a liter of coolant. Start it up, still on.. But this isnt the only problem, my dad noticed my car was dripping, i look and sure enuf its orange coolant.. Its leaking verrry slowly from i dont know where, i looked under the car and i cudnt see where it was coming from, it was just dripping off a piece of metal that didnt look important. I looked under hood and cudnt find a leak, its not a hose, doesent look like its coming from cap, bled the air, still.. It kinda looked like it was falling from under the pulleys, i didnt SEE it but that looks like whats happening.. Wud that be a water pump or something? Any way to make sure? Thnx
P.S. Its leaking from passenger side
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 05-16-2006, 09:19 AM
Re: Coolant Light/Leak
Well the coolant light came off, and over night it has only dripped a couple drops, so im thinking it only leaks when its running? Ill check it out better after, but at least coolant light is off, i did bleed it btw
Old 05-16-2006, 09:20 AM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
I have a 96 2.2, 182K .....with a small leak at the head gasket.....very hard to see....No water in oil.....No time to change it now...so I put in a can of BARS LEAK....stopped it...for now.....
Old 05-19-2006, 10:28 AM
lifelongslacker lifelongslacker is offline
Might want to check the water pump gasket, mine went at about 120K.
97 Rodeo 3.2L, KC Lights, Air Hog Filter, Flowmaster 50 Series, Maxxis Bighorn MT's, 2" Lift.
2004 F150 FX4, Stock, so far
Old 05-19-2006, 11:46 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
I was going to suggest the same thing, water pump or the gasket.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 05-19-2006, 05:21 PM
szym0n szym0n is offline
im getting the same problem but on driver side...mine is a 04 cavi with 24K miles on it....it was in a accident but my dad bought a new radiator and installed it correctly and it leaks still but alittle. It seems like its leeking from a gasket on the bottom driver side of the radiator...im not sure tho.
