Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 05-15-2006, 10:34 AM
EjectTheReject00 EjectTheReject00 is offline
Engine swap question: Ka-e to de
I'm going to be getting a 90 240 coupe soon, equipped with the ka24e motor. My plan is to sell my other car in order to buy a ka24de longblock and a stage 2 turbo kit for it.
My current question:
Would the accessories under the hood from the ka24e hook up right to the ka24de longblock? I'm hoping it all pieces together nicely.
Aaron
Old 05-15-2006, 05:20 PM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Re: Engine swap question: Ka-e to de
The ka24e to ka24de sucks...but maybe thats me. I say just rebuild the sohc and turbo it. There is plenty of aftermarket out there for it. if your serious about going ka-t i suggest you check out ka-t.org they have tons of sohc-t and dohc-t's
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 05-15-2006, 05:50 PM
Pavlo's Avatar
Pavlo Pavlo is offline
Good advice. For sohc to dohc conversion you will need the engine, tranny (maybe just bellhousing, not sure), wiring harness, and the ECU. Might as well get a nice built engine or CA, or maybe SR (RB sounds sweet too). Even though both are KAs the swap is just like it is for other engines.
VR6> Anything
FWD sucks for understeer? Swaybars do magic.
Old 05-15-2006, 07:03 PM
yup..he pretty much hit it on the head...however i wouldnt do and engine swap, i would keep the sohc and just build and turbo it...you'll still find that you'll get great results
Current cars:
Old 05-16-2006, 11:16 AM
Im sure the engine swap would be the same basic thing as any other engine swap, but im kinda biased for the ka24de. I've already been using one for the past year or so, and i love them basically. Plus, when turbo'd (which is my plan) they've got killer torque.
I would just rebuild the sohc ka, but i dont like single cam. Just personal preference, basically. I'm more used to how they act and what-not.
and ive found two stage II turbo kits, though im not sure which one i should go with:
http://www.import-autoperformance.co...0sxstage2.html
http://www.turbo-kits.com/240SX_turbo_kits.html (s14 stage 2 fmax)
Thanks for the help.
Aaron
Old 05-16-2006, 02:48 PM
mongooze mongooze is offline
ecu yes. wiring harness yes. tranny no, your sohc tranny will work. id say get a complete motor not a long block. everything is diffeerent. power steering, ac. etc. youll need a/c lines. even the ones in the dash..so basically a whole new ac system. and ka24de power steering lines. if you notice the sohc resevoir is on the pass. the de is on the driver..or it might be vise versa. but yea i did this swap and to me it wasnt worth it. i would def. just buy a de there still as cheap as a sohc. either get a de or just turbo the e. also get a 91 the stock camshafts have higher duration, unless your gonna upgrade the cams.
Old 05-16-2006, 09:32 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
the 91 year is a myth, its all S13 KA24DE exhaust cams that are 248, and intake is 242. Not just the year 1991, its proven. Id say swap in a DE, and turbo that. If your going to the trouble of swapping any engine, might as well be one you like...
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 05-17-2006, 01:42 PM
Thank you, hit and run.
i have looked for complete engines, anyone know where i could get one? all i can find are short/long blocks.
Old 05-17-2006, 08:18 PM
ok ok...yes the swap is easy, as long as your not using a s14 ka24de...becuase then you end up swapping the dizzy, harness, a/c and power steering lines...and some other minor stuff
Current cars:
Old 05-17-2006, 11:03 PM
so id still be able to use the ac if its a s13 block?
Old 05-17-2006, 11:11 PM
you should be able to...you might just have to use the s13 dohc ac lines though
Current cars:
Old 05-17-2006, 11:14 PM
well, im sure i can find somewhere around here to put it all in when i get the pieces. though thats the easy way out, itll be done right. plus ive got no garage.
