Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-15-2006, 11:03 AM
SySt3mR00t SySt3mR00t is offline
Send a message via AIM to SySt3mR00t
Oil Pan Gasket ... To be? or Not to be? That is the question!
Ok ... so im a little bit concerned here .... I know that the stock OEM gasket kits do NOT come with an Oil Pan gasket. My aftermarket gasket set came with a gasket. When i put the gasket on, now the oil pan leaks a little bit. Now what should i do? Put my oil pan on metal to metal, oilpan gasket metal, or oilpan RTV GASKET MAKER metal? Need a little help here to figure out which would be best to stop leaks? Also would it be easier if i just put some RTV GASKET MAKER around the outside of the oilpan where it touches metal to fix the leak ???
96 GST
Old 05-15-2006, 11:19 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Oil Pan Gasket ... To be? or Not to be? That is the question!
Use rtv or the right stuff and that will seal it up good
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-15-2006, 11:57 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 05-15-2006, 12:36 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah, just gaskets tend to leak. On Mike's car, we used a gasket and RTV and it worked good. I would just put a bead of RTV on it, no gasket.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-15-2006, 02:14 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
They came with rtv from the factory (well something like that) ultra grey is the kind you should use an 1/8th" bead all the way around and around the bolts should do, I had a gasket on my talon and it leaked like an sob.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-15-2006, 10:48 PM
kjewer1 kjewer1 is offline
AF - Advisor
EZ hit it on the head, Permatex Ultra Grey. This is actually what the factory uses, and it's even made by permatex. I got some from my brother who is a mitsu mechanic, and I can not tell the difference between the Mitsu stuff and the permatex ultra grey. But back on topic, I just use that, and no gasket. The gaskets usually do end up leaking.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
