Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-15-2006, 09:05 AM
bcopeland bcopeland is offline
1999 3.1 Heads
I was told that when you put heads back on, you should use gasket sealer like Copperhead or Indian Head to seal them. Is that what readers understand? I replaced my intake gasketsa qwith the problem sealer and apparently my rockers were loose (at least one), but it ran fine. That is until a week ago when it started loosing power and would shake real bad at idle. I'm wondering if I cracked a head because of the one valve not working or what. Head gaskets look fine and the heads look ok. Thoughts?
Old 05-17-2006, 12:52 PM
malibugtp malibugtp is offline
Re: 1999 3.1 Heads
if anything you prolly bent the valve, push rod or dinged the piston
Old 05-17-2006, 06:20 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: 1999 3.1 Heads
I believe the instructions on the gasket set specify no sealer. Second do a compression test and see if all cylinders are up to par, any check engine lite? Also check for vacuum leaks around the items taken off during the repair. Look for loose injector harness connectors, loose misfitted plug wires.
Old 05-19-2006, 08:14 AM
tractorboy's Avatar
tractorboy tractorboy is offline
Re: 1999 3.1 Heads
I have never heard of putting sealer on head gaskets. I would not do it. Usually most head gaskets incorporte some tyope of soft metal , either through out or just around the cylinders, that i guess flatens out a little as the heads are torqued.
Old 05-22-2006, 08:30 PM
Re: 1999 3.1 Heads
Well I put the heads back on. The car started like the battery was dying - 3 or 4 slow revs then a start. It did that most of the day. Finally, it died out like it was the battery. I replaced the battery and then it acted like the started was slow winding. It could be the starter or the alternator. Ever heard of such? PLEASE HELP!
Old 06-24-2006, 05:18 PM
Re: 1999 3.1 Heads
It was the starter.
