Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-15-2006, 08:55 AM
ChupaCabras72 ChupaCabras72 is offline
Gearbox Ratio?
I have one 2.5TD JGC98 I liked to know which Is the ratio of the gearbox.
thanks
Old 05-15-2006, 08:07 PM
JDPascal JDPascal is offline
Re: Gearbox Ratio?
thanks
Welcome to AF ChupaCabras72
Those number are not making sense to my North American brain.......
I am assuming that your Jeep is a 1998 Grand Cherokee but I cannot connect the 2.5TD to anything in my experience with Grand Cherokee's.
are you meaning that it is the LTD or "Limited" model not the "Larado"
Which gearbox is it? The automatic transmission, or the transfer case that makes it 4 wheel drive???
Which transfer case is in your jeep??
Someone will be glad to help you but we need more information......
JD
EDIT!!! Ok - I'm a dufus - thanks to a little help from my friend DK, I have been reminded that there is a european model witt a Diesel engine. Still need to know what transfer case it has unless someone has the ratios for any and all......
Or -- you could crawl under and have a look at the little round tag that should be there on the back of the transfer case. The tag has the model and ratio stamped on it - at least on the models here on this side of the pond...
Gee's what a nite!!!
If ya can't fix it right the first time, how ya goin ta find the time ta fix it again????
Old 05-16-2006, 01:05 AM
Re: Gearbox Ratio?
JD
hi JD thanks for help
yes its a european model its a 2.5 Turbo Diesel engine make in Italy by VM and the car it was made in Austria, its a manual gearbox hit five speeds.
ok im gona check if t bottom for the gearbox have a number.
thanks JD
Old 05-16-2006, 07:23 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Gearbox Ratio?
Man, I would love to have a Grand Cherokee with diesel and stick!
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-16-2006, 06:48 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Gearbox Ratio?
ok I am assuming you have the AX-15 Transmission....
1st gear - 3.83:1
2nd gear - 2.33:1
3rd gear - 1.44:1
4th gear - 1.00:1
5th gear - 0.79:1 (overdrive)
Reverse - 4.22:1
Old 05-17-2006, 01:33 AM
Re: Gearbox Ratio?
it is a very good machine, makes 11 liters to the 100Km is not bad for a 4 weels drive the power its onle 115hp , it is enough
thanks
Old 05-17-2006, 02:46 AM
Re: Gearbox Ratio?
1st gear - 3.83:1
2nd gear - 2.33:1
3rd gear - 1.44:1
4th gear - 1.00:1
Reverse - 4.22:1
hi dksob81,
this values are the put in one excel program + the measure of the tire go to give me the maxime speed of the each gear; cool
thanks
